ST170 Aftermarket Cams+VVT worth the risk?
Can you safely fit aftermarket cams to an ST170 and still run the VVT on the inlet, i know there has been a few casastrophic faliures once the VVT switches and pistons have met valves. Even the manufacturers reccomend NOT running the VVT with their cams but i want to keep mine and fit some Cat cams
