autogauge tachometer(rev counter)??
Old Feb 4, 2011 | 07:31 PM
mikey200615's Avatar
mikey200615
Default autogauge tachometer(rev counter)??
hey folks as above anyone fitted one of these autogauges after market rev counter? i know that when the ignition has a coil the green wire off the gauge is meant to go to the negative side of that but what do you connect it to when its got a coil pack??
cheers for any help/advice
mike
Old Feb 5, 2011 | 03:28 PM
martysmartie's Avatar
martysmartie
I think there is still a take off for the coil pack? Not to sure tbh as all modern cars tachos are fed via the ECU.
Martin
Old Feb 5, 2011 | 05:38 PM
You simply take the feed from one side of the plug, ie "half" the coil, so it reads only 1+4 or 2+3, you then adjust the cylinder setting on the tacho to read right.
On a zetec coilpack for example with the three pin plug, the centre is live, and the outer wires/terminals are negative, or "green" on older style coils.
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
