mk4 van rear suspension
Old Feb 8, 2011 | 08:59 AM
mk1trb's Avatar
mk1trb
Boost Junkie
Default mk4 van rear suspension
are they the same set up as the later vans with the springs on top of the axle of under it? my one the axle is on top of the springs but doesnt look that low? how do you lower one aswell?
cheers
Old Feb 8, 2011 | 12:19 PM
AustenW's Avatar
AustenW
There are two ways you can lower it
Either get your existing springs decambered (bent) by a specialist to lower the ride
Or relocate the axle above the springs, with u bolts and a adapter plate
I did both on my van with some arch mods and it looked super low
You will also need to remove the rear bias valve to stop the back end locking up and fit an adjustable bias valve
Old Feb 8, 2011 | 12:22 PM
AustenW's Avatar
AustenW
Old Feb 8, 2011 | 02:08 PM
mk1trb's Avatar
mk1trb
Boost Junkie
my axle sits on top of the leaf springs and with 17" fitted there still an inch gap between arch and tyre, i always thought it lowered them more than that??
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
cossirob
Sep 3, 2015 09:17 PM
Bighandsuk
Sep 2, 2015 05:23 PM
