thumping noise on 2wd cosworth
sideways most if the time
Hi , i have just recently acquired a thumping noise on the car.It sounds like it is coming from under the car around the prop. It only happens when on the move,the faster i go the faster it go's.. It sounds as tho the prop is banging the floor when it rotates.
Any idea's ? or is it worth changing the center prop support bracket rubber ?
Thanks
Thanks
FlashRS
13
31-08-2015 06:02 PM
