YB info?
Old Jan 29, 2011 | 08:23 PM
Boomerang's Avatar
Boomerang
Default YB info?
Few questions for you lot.
I've heard of people running YB's N/A.........I'm guessing this makes it a strong Reliable engine.
What mods could you make to get decent power and how would you go about it.
What would you expect to pay for a engine without turbo or what would you need to do to make a standard YB non turbo??
What would you expect to pay for a standard turbo YB?
Thanks
Hugh
Old Jan 29, 2011 | 08:56 PM
The reliability comes from the bottom end being so strong as std, but for n/a the CR will need raising a lot, so new pistons as a minimum, not the best engine in the world for n/a imo, in ford terms I'd go duratec but depends on budget as well, the cossie crank is bullet proof for any n/a power level as are the rods.
I'd also look at vaux xe engines a lot better bhp/£ on n/a than converting a yb.
Old Jan 29, 2011 | 08:57 PM
LHD220Turbo's Avatar
LHD220Turbo
very very expensive from what ive seen - what's the application?
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Mc5506
Sep 29, 2015 09:06 AM
