PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 [112] 113 114
  1. External Wastegate
  2. als ?
  3. Sensor on gearbox
  4. Exhaust manifold studs on a 2wd cossie
  5. S2 not holding boost
  6. Misfiring cossie 4x4.
  7. no power to metering head
  8. 4wd 2wd gear box lenghts
  9. What tests do i need to do.
  10. FRST Problem
  11. cabriolet electric roof
  12. 3dr side skirt Removal
  13. 20 zvh engine parts (needed asap)
  14. pleeze help smokin motor
  15. solenoid control valve[2wd cossie air filter]
  16. live mapping
  17. what tuning for a Mk6 escort 1.6 zetec
  18. 4x4 gearboxes
  19. what oil
  20. brake line kit
  21. Bottom End Problem
  22. apexi gauges
  23. Induction kit?
  24. how to correct fuellin ?
  25. Am i running rich?
  26. Problems with S2 lights
  27. Backpressure
  28. Map Sensor Codes
  29. How can i find out if my stem seals are knackered!?
  30. stage1 tune up
  31. Escort Cosworth gearbox??
  32. Fiesta exhaust
  33. Heater Motor
  34. Hi can anyone identify finis code: 9097994 for me please.
  35. Are Escort Cossie and Saf 4x4 Cossie chips interchangeable.
  36. my month old turbo is smokin!
  37. Changing 2wd Cossie turbo
  38. Changing 2wd Cossie tyrbo
  39. 8 injector setup?
  40. What is safe boost for T2 hybrid?
  41. fumes smell
  42. Bailey breather question
  43. gearbox swap
  44. I/Coolers, Lag, max psi etc
  45. my fiesta rst playing up
  46. S2 Fuel computer Help!!!
  47. 2.0 zetec conversion
  48. what fuel pump
  49. Fitting cossie plugs to a zetec head!
  50. over voltage protection device (where is it?)
  51. can u have two headunits in one car?
  52. Efi to Turbo
  53. URGENT HELP!! COSSIE HEAD GASKET???
  54. What Turbo?
  55. gaz
  56. Controlling Air Injectors with a Electronic Boost Controller
  57. Best spark plugs for RS turbo escort?
  58. big end movement
  59. 1.6 zetec cuts out when cold
  60. Electrical question: block connectors
  61. oiley turbo!
  62. RST S2 PLUGS. WHAT SIZE GAP DO I NEED ON MY CHIPPED RST?
  63. Fiesta RST Irregular fueling problem!!!!!!!!
  64. FRST Map Sensor Problem?
  65. Piper cam timing on S2 erst
  66. Mk5 Xr3i Cab 105PS - £1000 To Spend On Engine
  67. Smokey cossy
  68. oil pumps
  69. Cossie Stage 3 Missfire Problem
  70. Urgent help/advice needed cos engine trouble
  71. A cloud of smoke!!
  72. Would a S2 head fit a FRST block?
  73. T34 .48 or .63 housing,advise needed.
  74. Sapph 4x4 breating issues
  75. my xr4x4 turbo technics
  76. rear driveshaft cv joints 4x4 saph
  77. Escort to sapphire Cosworth Rear anti roll bars
  78. RS500 I/coolers
  79. Cold start up - non idling
  80. what's needed 4 efi conversion
  81. handbrake cable removal......
  82. 4 x 1000cc or 8 x 480cc injectors Which would work best?
  83. tyre
  84. Willwood calipers, need pads urgently
  85. escort cossie
  86. Sensor inside Dizzy, mines Toast . Where can I get a new one
  87. help need with AVO suspension
  88. heated rear screen /aerial
  89. LSDs
  90. S2 not starting help please!
  91. leather interior
  92. Fuel Pump Running and Wiring
  93. ABS light on S2 keeps flickering
  94. 2wd and 4wd pleums
  95. engine swap 1.3 hcs to 1.4 cvh?
  96. Headlight Relays(S2)
  97. Twin turbo zetec
  98. cossie throttle body
  99. help no power 2 fuel pump
  100. cosworth conversion
  101. stg3 cossie not holding boost?
  102. 4x4 rear crossmember bushes
  103. In need of a re build
  104. Group A coil?? Is the Pos(+) at the top or bottom???
  105. 1.3 OHV to 1.6 CVH in a mk4 scort
  106. cossie managment
  107. cossie managment
  108. 1900 CVH American Tall block
  109. ACT GAUGE
  110. PECTAL ENGINE LOOM
  111. S2 rst problems again.. SOLVED! :)
  112. Cosworth Experts Please......
  113. Escort cosworth hard starting - Can anyone help?
  114. Escort Cosworth clutch pedal question . . .
  115. Sapphire & 3Dr Steering Knuckles , Are they the same ??
  116. new cars not right.
  117. bodywork
  118. Help with Cossie management on a S2
  119. coil over springs.....
  120. help with S2 loom in my orion!!!!
  121. my cars suffering with cold, plz presribe remedy
  122. Any one know who might stock.......
  123. how to join to looms to make one
  124. Help starting problem H reg s2 rs turbo
  125. zetec ecu swap
  126. cvh head
  127. Fuel Injectors! Technical Explaination Request!
  128. erst....Koni struts
  129. Rear suspension bushes, anyone know how to change them?
  130. XR2I 1600 zvh convertion???? HELP!!!!!
  131. Actuator ID & intercoolers
  132. help needed on s2 rst
  133. S1 Gear selector rod, please help!!!
  134. EFI fuel pump on MFI system...
  135. misfire or glitch in revs on FRST!!!
  136. rs1600i cutting out fault.
  137. Rebuilding a 4x4 Cosworth Bottom End
  138. Rs Turbo
  139. Head Joint
  140. Quick Gearbox question ?
  141. engine monitors
  142. powerflex rear beam mount bushings
  143. idiots guide for fitting fan override switch???
  144. Head change!
  145. Clutch pedal vibration
  146. 2 annoying problems
  147. Fitting AP 4 pots
  148. chips
  149. Mk2 fiesta brakes upgrade?
  150. Poly bushes f, sierra GT
  151. using a fuel pump as an oil pump?
  152. changing over to 4x4 management
  153. removing a engine with out a crain? --:: HELP ASAP! ::--
  154. Zorst
  155. Can't find alignment mark on Dizzy sprocket TDC setup
  156. my fez turbo wont start
  157. after market rs turbo van exhaust question
  158. mk1 fiesta tuning
  159. best way to mount mesh
  160. Help...... Is my gearbox fooked???
  161. adjustable TCA's
  162. engines/ and looms
  163. cossie 600bhp throttle body choices?!?
  164. fuel filter
  165. Fuel pump question - power needed for Greys?
  166. difference in rocker cover colours
  167. injectors
  168. S2 Power Steering
  169. Cossie management
  170. boost problem
  171. luminition throttle bodied 1700 xflow-HELP
  172. oil breather
  173. Modifying a 4x4 shell to 2wd
  174. Turbo
  175. Need Help.....20bhp resistor?!?!?!?!?!?!?!?!
  176. xr3i tuning and engine mods
  177. Central locking
  178. xr2i 16v tuning
  179. d-locked
  180. Tyre sizes
  181. COSSIE BREATHER SYSTEM?
  182. Bosch number
  183. Series 3 Zetecs Qu's??
  184. 3i / turbo springs..will they fit?
  185. White Sludge
  186. 4x4 saff running like a dog
  187. 3dr rear suspension ?
  188. amal valve
  189. GP N Gearbox?????
  190. What size Tyres ???
  191. 205 blocks
  192. Changing engine management chips.....
  193. Cambelt cover
  194. Series 1
  195. "Grp A" Coil question . . .
  196. please help !!!!!!!!!!
  197. ERST Hesitation
  198. bw t56
  199. Is 330mm the biggest with AP 4 pots??
  200. ICE PROBLEM
  201. sierra fuel tank
  202. escort gti abs light staying on
  203. Gearbox Spigot Shaft
  204. Fitting an RS1600i Steering wheel.............
  205. engine problems a possible cure?????
  206. diff oil
  207. help!!!
  208. WHAT PARTS TO RENEW???
  209. wilwood brakes - bleeding???
  210. flamer kit
  211. COSSIE ENGINE LOOMS
  212. All Cosworth cams listed - Please help.
  213. looms !!!!!!
  214. RST fuel gauge!! help
  215. secs monitor volt reading
  216. any air filter 4 a 1.3 escort ??
  217. MISSFIREING COSSIE
  218. Esc cos fuel gauge
  219. head gasket cossie and long studding advice please
  220. Mondeo V6 Lowering
  221. its a long shot....
  222. Standard Cossie Cams Timing figures???
  223. My SECS Monitor shows my MAP -0.9 when the engines off?
  224. Escort Cosworth - My Spec, what next!!!?????
  225. 2WD PROP
  226. CAMS BD14'S (will they or won't they)
  227. How do you remove the steering wheel?
  228. 17's on a fiesta
  229. NEW ECU STUFF
  230. RS 500 Plenum over a std one for 4 injectors ?
  231. Door wont close
  232. carbs
  233. Cold temperature enrichment
  234. Paint or Powdercoat????
  235. Starting Problem!
  236. Saph cossie axle
  237. Saph cossie axle
  238. swap a cosworth engine in to a escort mk2
  239. Pectel board???? cosworth
  240. Fitting Foci repeaters to Escort mk6
  241. Shaking XR4X4
  242. Zetec Turbo help please
  243. mk5 springs on a mk6
  244. wots a breather pot do?
  245. Identify Pistons Cosworth
  246. Esc cos oil pressure?????
  247. MK4 Escort Rev Counter Fitting ::HELP::
  248. BIG brakes
  249. water temp sender ...
  250. removel ov oil pump and then refit 2wd cossie
