My SECS Monitor shows my MAP -0.9 when the engines off?
As title - is this normal? Anyone else with a secs show different? Bad earth to map sensor?
I also have a SPA boost gauge and the SECS guage are off by like 3.5-4 psi at full boost (like 26 psi).
Anyone else have a difference in boost gauge to ecu monitor?
not to sure on the boost gauge but iam on a 3 bar as well it seems to be the norm then try secs they might be able to tell you the reason for this
1 Post
exactly.
manifold ABSOLUTE pressure - not gauge pressure, a so a gauge will read 0 when the absolute pressure may be slightly above or below 1 bar absolute at different atmospheric conditions
JoeyBoyden
18-08-2015 10:52 PM
