PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 [99] 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114
  1. fitting mondoe v6 brakes to my ka!!!!!!!!!!!!!!!
  2. Bleeding ABS pump?
  3. 2WD FAN SWITCHING ??? quickie
  4. 3BAR MAP SENSOR TESTING???
  5. actuators
  6. Focus speedo cuts out, then car cuts out.
  7. cold start up
  8. help/advice needed please!!,Turbo sorted now
  9. mapping your own chip
  10. Whisking noise from exhaust ?
  11. Stage one boost setting
  12. s2 tst wont rev about 5500 , sounds like misfire???
  13. Puma conversion
  14. Heavy power steering
  15. Flamer Kit
  16. rev Counter only showing half revs it should
  17. s2 fuel prob
  18. xr2i wheres the fuel pump
  19. why wont my s2 start!?!
  20. Smokin Cossie (there's a new one)
  21. engine blown
  22. Torque settings
  23. boost gauge
  24. ESC COS WON'T START!!
  25. metalic clunking ????
  26. throttle positioning sensor
  27. blowing exhaust
  28. pinto rattle help
  29. stalls on cold start
  30. HELP !!!!!!!!! car dead
  31. best zorst valves for running ALS
  32. 1.6 Bored to 1.9 Carb to Turbo Conversion.
  33. Ignition amplifier - any equiv?
  34. rs 500 help
  35. help!! Rs2000 questions
  36. Chargecoolers
  37. fiesta suspension...
  38. 2WD Cossie Front calipers onto S1 Turbo?
  39. exhausts
  40. idle problem
  41. Zetec Turbo
  42. s2 turbo engine to mk5 escort??????????
  43. Heater and wipers pack in 1988 escort cabby help!!!!
  44. FRST oil?
  45. cold start
  46. diy MegaSquirt ECU's
  47. timing up a ZVH lump
  48. ford f150 cambelt
  49. t3 sharft
  50. 2 LITRE ZVH HEAD GASKET
  51. idle speed help
  52. My cars having a funny turn!!!
  53. Breather cleaning on my cos ?
  54. ZVH
  55. mk v van--rst engine
  56. cossie water drinker
  57. ford ka engine conversion
  58. zetec piston pertrusion
  59. T3 turbo differences
  60. does any one know how to up the rev counter output
  61. boost problem with my saff
  62. ford Keycode Help!!
  63. internal petrol tank
  64. Boost Prob on me S2!!!
  65. Best oil for a modded but evryday use RST Please
  66. Turbo problems !!!!!
  67. [b]PROJECT RS 1800[/b]
  68. rs 2000 fan dont work
  69. fusion oil breather 4 pipe
  70. why does this get so HOT
  71. engine management system
  72. Ford spark plugs..........
  73. Radiator fan blowing fuses?
  74. Gearbox terminology?
  75. Dump valve, 4x4 saff
  76. lift pump for swirl pot????
  77. Bearing carrier to strut fittment strengthening?
  78. wipers????????
  79. Wheel sizes on a 2wd saphire cos?
  80. fuel pump not priming
  81. Change of Power steering fluid for a 2WD Saph.
  82. escort cosworth fuel filter
  83. How much power will my turbo produce?
  84. Exhaust
  85. Will MTX75 fit into my RS turbo
  86. s2 injector hose removal??
  87. 1800,zvh head gasket
  88. removing door cars, N reg escort?
  89. where can i get essie cos cylinder head
  90. flywheel info needed asap
  91. Blooooody loud car
  92. Blooooody loud car
  93. problem starting car
  94. ZVH CONVERSION AND GEARBOXES
  95. s2 misfirin under load
  96. wiring diagram for 24 v cosworth scorpio
  97. please help with clutch problem i think
  98. Anyone know if there is a difference ?????
  99. fiesta bonnet cable snapped
  100. Possible reasons why Fans wont kick in???
  101. Rs 500 injectors
  102. 2WD cossy brakes on a MK4 cabbie
  103. PRESSURE SWITCH FOR AN RST
  104. escort rs turbo
  105. 3 dr header tank
  106. CAN I USE COSWORTH PISTONS IN A ZETEC BOTTOM END
  107. Escort RS2300 Problems, anyone?
  108. xr3i tuning?!?!?
  109. Loss of power and idles at 500rpm! HELP!
  110. NA 1800 zvh Questions.....
  111. efi starting trouble wen warm
  112. fiesta hard to start in morning
  113. 1990 h plate erst
  114. RS 1800 parts to EscortGTi
  115. dunp vale
  116. cossie electric fans
  117. Identify the engine please? (pic)
  118. are escoss seatbelts different from standard escort
  119. focus st170 breaking system on a s2
  120. bleeding the water system
  121. over heating on 3dr cossie
  122. paint codes?
  123. help on erst brake upgrade to cosworth??
  124. fueling
  125. Help relay problem on my 300bhp 2wd saph
  126. Problem or not?????
  127. zetec e
  128. noise on engine? sounds like tappets.
  129. does any know what chip this is?
  130. S2 running probs
  131. spark plug lead setup
  132. Distributor Pulley
  133. ERST into Fiesta 1.1
  134. Oil light
  135. injectors
  136. REALLY WEIRD Electrical problem on a 2WD Saph!!!
  137. compression help!!!
  138. 2wd oil filter cooler???
  139. Help on body kit for mk 4 fiesta
  140. 4X4 SAFF SUSPENSION
  141. trackin & camber setup equipment?
  142. carb screws
  143. Cant start my cossie capri!
  144. escort starter motor Question
  145. 3 door coil overs
  146. what gearbox do i need
  147. Escort Cossie on 18's......Wheel nuts?
  148. where does this go then........
  149. Head gasket possibly??
  150. ford focus tddi
  151. help Oil pump 4 a 2wd saff
  152. Series 2 - External Wastegate??
  153. Wheels & tyres
  154. mystery driveshafts
  155. revs rise then wont start
  156. 2wd cossie giving out smoke in engine bay?
  157. 2wd smokey joe???????
  158. HELP p100 panels/suspension
  159. slick tyres
  160. help..1.6 16v escrt 3dr mexico 1995 mods
  161. Focus Coilovers
  162. 2wd Saph any ideas ??????
  163. help
  164. oil breather return?
  165. Spray Bar / Oil Pickup pipe Cosworth
  166. smoking fiesta
  167. s2 headgasket replacement
  168. Squeeky steering
  169. 2wd cosworth pulley problem ?
  170. custom wiring looms
  171. any ideas ?
  172. fan switch on a rst
  173. gearbox man is he any good
  174. pinto ignition problem.....
  175. aaaahhhhhhhhhh
  176. Cossie amal prob
  177. wiring loom conversion question
  178. ERST OIL LIGHT FLICKERING ???
  179. rs16i valve stem oil seal size
  180. hy
  181. Multi-plugs?
  182. erst brake problem!!!!
  183. Speedo not working?
  184. Koni adjustables..urgent !!
  185. 2.0L Zetec MK2 Fester Project
  186. brake pedel
  187. RS turbo distributor
  188. me nephews sapph 2wd
  189. gearbox
  190. help please could have a problem
  191. help please
  192. Escort Rev Counter
  193. Boost on 2wd cossie
  194. ECU
  195. Were fiesta turbos made on a G reg
  196. S2 boostin problem
  197. No power when hot??????
  198. 1.3 escort, over feuling, or not getting air??
  199. polishing turbo housing?
  200. smooth running problem
  201. cosworth onto pinto mounts
  202. escort mk2 axle
  203. HKS ECV setup problems
  204. RST overfuelling??
  205. Running Rich
  206. 2wd cossie into 4x4 estate
  207. s1 vacuum hose?
  208. anti roll bar clamps escort s1
  209. dump valve
  210. cossie oil
  211. Low fuel indication circuit failure short to ground
  212. Capri 2.8 Type 9 Gearbox Question...
  213. Alloy wheels (3 door)
  214. stander ride hight on an escort cosworth
  215. Please help knocking XR3I and model query!!!
  216. I KNOW YOU WON'T LET ME DOWN
  217. xr2i power prob
  218. exhaust on erst
  219. Speedo cable -> Escos
  220. 4x4 Diff pinion seal leak..again
  221. st220 alloys
  222. Fiesta Radiators
  223. ford ka alloy fitment question??????
  224. HELP MAJOR BATTERY DRAIN
  225. MAJOR PROBLEM?????????
  226. cylinder lekage 2wd cossie
  227. turbo conversion
  228. 2wd abs light
  229. Cosworth Exhaust Valves: Who does the sodium filled ones?
  230. YB compression heights
  231. saph cossie water pressure.
  232. 2.0l dohc want more power
  233. chip need ure help here
  234. 2.0 twin cam idle valve
  235. wheel fitment on saff
  236. normal saph cos running temperature?
  237. 1.3 Endura running problem
  238. sapphire cosworth air-condition info
  239. erst oil/crank case pressure problem (keep killing gaskets)
  240. escos ABS pump
  241. Inlet KPA and cam timing
  242. fuel comp
  243. wiring issues
  244. tapping noise
  245. fuel pressure
  246. Will a -31 or -34 uprated cosworth actuator fit straight on
  247. gear box swap
  248. can anyone tell me wht this is???
  249. magnex exhaust help please
  250. 803 dark greens
