timing up a ZVH lump
May be a daft question but how do you go about timing up the zetec bottom end with the cvh top end?
Dave
Dave
Ignition timing or valve timing????? Ignition timing, theres a lug on the sump so mark on the crank pully a TDC mark and then set it up using a strobe lamp. Valve timing, you'll need a vernier pully for the cam as the zetec block is taller and if I remember right (was about 5yr ago that I last built a zvh tho lol) the belt teeth fall between 2 teeth (you'll end up either a tooth advanced or a tooth retarded) on the pully wiv out a vernier pully to line it up right. Hope thats of some help to you
slammedorion
15
Nov 1, 2015 07:17 PM
blackbeautyzetec
Sep 11, 2015 03:10 PM
