1.3 Endura running problem
I there, I have a problem with a newly aquired Ford Fiesta 1.3 Endura Ghia (1996). On the odd occasion it will cut out when slowing down with the clutch depressed. In addition the car will sometimes act like it starved of fuel at idle speed and when driving along at a steady space. It judders slightly, but usually by opening it up a bit, it will temporarily solve it. I've read that it may be the speed sensor attatched to the gearbox, but do any of you think otherwise?
Hope you can help, many thanks.
ive got the same car same year same problem, i found a vaccum leak from the oil filler cap breather hose to the inlet manifold i replaced the pipe and seems to have cured the problem, if c if u have a vacuum leak lift the bonnet start the engine and then switch off, if there is a leak u will hear a sucking sound for a couple of secs after the engine has been switched off
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
