1.3 endura e engine
Got to replace my cylinder head as the spark plug cracked off on service. Stupid previous owner over tightening and not replacing them often enough.
Anyway, got one eyed up on eBay. Is the Fiesta 1.3 endura e the same as the ka endura e of similar year?
Little trick for the future. Fill the plug recesses up with wd40 and get the engine red hot. Turn it off and quickly go to undo the plugs. Never failed for me but seen loads of people break them trying to undo them from cold! Hope u get it sorted
Do as gfcos says next tine but you can get the plug out still , gently remove the rest of the porcelain off the plug and use an easy out to remove the rest . If you do this be extremely careful you don't drop any bits down the plug hole .
Originally Posted by Bobby9779
I used an easy out. The threads were that tight even that didn't work. Burnt out a drill and bent a breaker bar trying an easy out.
I dont particularly like to use copper grease on spark plugs as I've had a few issues with old grease that's gone rock hard and made it difficult to remove the plugs. However if they are replaced yearly copper grease shouldn't be an issue.
I tend to use a ceramic grease these days though, especially on glow plugs.
Stuff worked well. In fact when I fitted my brakes on my Cossie there that was about 5 or 6 years ago and u can still see the ceramic on the back of the pads where copper grease would have washed away by now
base190380
Sep 3, 2015 08:32 PM
