View Full Version : Technical help Q & A
- what the difference between 2wd and 4wd inlet
- 2003 Astra Wheel bearings
- Ofac or Ofab on frst
- Horn still won't work....
- cossie downpipe size?
- The usual rust problem!! anyone no a good bodyshop?
- Air Con wiring help!!
- escort rs turbo cold start
- Cosworth trim into a 5 door hatchback sierra
- fitting 4wd engine into 3 door???
- cosworth engine starting problems!!
- Whats this out off??
- Urgent CR Help needed
- Are 17 inch wheels ok on a mk 5 escort?
- mk3 fiesta 2 litre zetec fuel pump
- Focus ST170 timing belt help
- boost dropping off tunner said.......
- Black top zetec advice??
- 2wd drive manifold on 4x4?
- Suspension help
- Location for a facet fuel pump escort mk4
- AP paddle clutch
- Thicker Engine Oil Over 100,000??
- rs turbo running problem
- cosworth dash
- series 1 turbo wipers
- Cossie 4x4 rear calipers?
- fiesta turbo running issues
- Fiesta RS turbo HELP!
- Escort Prop
- Escort Rs Turbo Engine Noise Help!
- Fiesta Zetec S problem....
- fiesta running flat and slow
- COSWORTH 2wd PRESSURISING !! HELP??
- saff 2wd misfire
- Power Steering Pump? problems
- removing escort rs turbo asb system
- Opinions on intake design.....
- Cossie Oil ?
- Rear anti sway bar on Cossie 2wd Saphire
- play on clutch pedal
- A few small problems....
- s2 boost setting
- mfi to efi
- boot soleniod esc cos
- S1 wierd missfire/lack of power 6-7psi
- actuator setting
- Gearbox for RST
- could i fit these wheels on my door with out any arch work?
- frst running probs!!
- Legaly Toooo Low!!!!!
- edfc controller
- Your Not Going To Beleive This.........
- 2wd diff ratio
- Focus RS Air-con connections??
- CVH to Zetec swap in a '82 (mk3) Escort
- Fiesta RS1800i ABS issues
- rear radiator
- turbo and n/a piston rings different?
- Escort GTI switching 3-4 cylinders and misrifing!! URGENT HELP
- Cos oil pumps?
- efi conversion . whats this ?? lol
- loom differences..
- Trust electrical
- car wont start
- megasquirt
- Spool up
- decat pipe
- Engine advantages
- Serious discussion for Electrical Guru's - Grounding points
- Autronin
- lumpy ticker...
- Help. blue smoke!
- Turbo choice, Cosworth 2wd
- floor pan
- S1 escort turbo engine oil
- 2.1zvh question
- mechanical abs
- 1.8 Focus Exhaust Manifold and de-cat
- MK4 Suspension Alignment Settings
- Fiesta Mk3 wont start
- CVH Timing. Valves and Ignition.
- Focus st Help
- My first XR3i..
- 1.8 turbo diesel
- Heater pipes
- saff 4x4 turbo
- Rear suspension
- 400bhp YB needs firing up again after 2 years! Help needed with wiring and plumbing
- Sapphire 4x4 problems, help needed
- lsd???
- windscreen removal?/
- Mondeo (V-Reg) Key cutting?
- C02 emissions
- Focus mk 2 Cosworth
- can any do a step by step walk throught of changing omex550 settings
- Cosworth SPARK plugs
- just done a compression test on mates car because it starting bit funny
- urgent help please wheres the idle adjustment screw on a escos small turbo
- ok im such a retard and need a haynes manual
- 4x4 Cosworth Rubber Donut Coupling
- Cosworth Stg3 330bhp
- scraping noise
- Electrical problems
- More than the one rack
- 2 pot rear calipers and handbrakes?
- 1994 Escort Alternator, Advise.
- Is 1.6 air box the same as a 1.8 zetec escort
- Taking appart an EDIS module connector
- Help Fitting New Shocks And Springs On Mk4 Escort Van
- help
- Gt 35 Turbo Help
- Escos running issues, Any ideas
- does anybody know?
- xr2 mk2 gearbox question URGENT
- Best place to get a T34 turbo refurbed.. ?????
- 97 escort fusebox help??
- Running in a turbo engine...
- Escort Cosworth ABS light on...
- Duratec, Omex, Throttle bodies... issues
- best managment for zt
- zetec bhp
- ford ka 1997 keeps juddering when driving
- Sapphire Cosworth 2wd rear axle crossmember
- what tire/ tyre advice
- Boost gauge hookup
- escort 1.6 lx zetec 1996 problem
- torqueing the head up
- Mondeo ST200 - ABS Light On!
- Power Engineering Cam Covers For The CVH
- Electrical prob with Mk3 fiesta....
- what size is oil fitting for turbo oil feed pipe ?
- which bolts
- 500 escos
- cosworth injector filter removal
- oil temp on frst
- what would happen!!!
- Sludgy CVH Oil.. Niiiiiice
- manual boost controller
- More Power for Escort Cosworth?
- Which Turbo?!? Fiesta Cosworth
- 130bhp cams
- Pace Charge Cooler help!!
- Zetec ECU
- rev counter showing half revs!!!!!!!!!!
- s2 escort turbo / oil everywhere?????????
- Cosworth 2wd & 4wd Piston differences?
- Stage 3 cos co2 set up?
- Simple CVH Starter Motor Wiring..
- fuse box
- Escort roof weather strips
- sierra xr4i
- sierra clutch cable
- oil seperator/breather system help
- frst not boostin
- 3 Door Cosworth Funny Engine Nosie
- Battery Drain
- best injectors for rst
- Fiesta mk5 remote key
- Mk3 Mondeo door card
- drilling cosworth cam cover
- mk4 escort wheel bearings
- Pistons and rods for Zetec turbo
- xr4x4 diff
- fitting oil temp guage to frst
- oil temp
- Left/Right Play in Steering Column
- boost probs again
- 1.8 Zetec - Swap For CVH Turbo?
- will saff cossie diff fit on a hatch 1.8 sierra
- fiesta rst injectors
- Billy Break Bleeder
- GT28 fitting
- hyd clutch set up
- Escort wiring...
- ford don't sell cossie woodruff keys help
- Using a lot of fuel!
- Saph Cos recaros in mk6 escort, subframes?
- Area 6 cam timing Help!
- after iv cleaned my engine
- Engine Management Light
- MK6 Steering
- 4wd cos oil pump/spray bar in a 2wd
- How to weld rear diff / 1.8 sierra?
- brake servo pipe to where?
- Series one exhaust
- Help Please Cossie Cutting Out On Boost
- Urgent Help Needed!!
- oil separator fitting
- anti lag questions
- Cosworth Fuel Pressure
- High comp NA Zetec, how to calculate CR
- Mk1 1100 go faster advice required
- Zetec quickys
- Lightened flywheels
- help with new cossie
- Tyres to fit 7.5j wheels
- cossie inlet manifold
- Searching for Idlevalve
- escort rs turbo wont fire up
- kidney box removal
- escos horn? plz help
- s2 rst idle problem
- Its not what ya drive, its how ya drive!!!!!
- How Do You Changs Valve Stem Oil Seals On Cvh Without Taking Head Off
- RST 2 Sensor ?
- 3dr rear diff
- Custom exhaust line for escort 1.6 CVH
- Escos randomly cuts out....
- decomplate
- dump valve
- cossie head bolts
- sierra cosworth 4x4 Brake hoses
- hubcentric spacers
- wiring in an OFAB loom to a zetec based mk6.
- Escos fuel tank
- 2.1 zvh where can i get pistons from???
- Con Rod Help.
- Whats The Difference
- mk6 escort td pump
- 1.9 cvh tall block engine
- rs cosworth 3 door guage showing engine hot after thrash
- how much is diagnostic?
- need help and so does my car
- will escort mk4 seats fit in a mk5van???
- escort rs turbo to efi help
- Rs 2000 Mk6 with ABS Rear disc Conversion
- 1.6 zetec errating idle
- Escort Cosworth Water Hose
- piston tdc escort rs turbo ??
- smoke from the breather system
- Turbo query
- when fitting plenum spacer
- abs removal on a erst
- Zetec runnin omex
- idle speed control valve
- read disc conversion help
- Help With I4 Rs2k Engine
- Request for dimensions or CAD for ford gearbox pattern?
- mk4 escort van... the black beast
- RS1800 loom to Mk5 escort..??
- mt75,difff....layout
- L8, wasted spark, crank/cam trigger...etc.
- ESCORT COSWORTH. differences: older and newer one
- fiesta turbo back firring
- Esy Reversing light switch - more problems?
- ST200 flat spot... suggestions?
- TPS sensor on EFI
- Drinks fuel!
- Welding : Is It Really That Hard?
