what the difference between 2wd and 4wd inlet
25-09-2008, 03:13 PM
Also if different can i use a 2wd one on a 4wd car,And r the 2wd and 4wd alloy engine mounts different
25-09-2008, 05:29 PM
The 2wd inlet has a seperate elbow between the throttle housing and the plenum, whereas the 4wd is one piece.
25-09-2008, 05:35 PM
what one best and can i use 2wd on a 4x4 car
cheers
25-09-2008, 06:00 PM
the 4x4 one is better than the 2wd one.
if you have a 4x4 one, keep it! - unless you want big power, than go with a plenum
26-09-2008, 02:51 PM
Quote:
Originally Posted by
ASHCOSSIE
As say up, + fuel rail mounting are différent.
You can't fit a 2wd fuel rail on 4wd manifold inlet without modification.
Regards.
Claude
3doorcozmess
15-09-2015 06:06 PM
xrmalin
13-09-2015 06:52 PM
dojj
28
11-09-2015 10:00 PM
rsstav
07-09-2015 04:43 AM
jc1989rs
05-09-2015 08:09 PM
