brake servo pipe to where?
Old Sep 7, 2008 | 05:34 PM
BIL N KEL's Avatar
BIL N KEL
Default brake servo pipe to where?
we've just put a rs2k engine on throttle bodies in my bro's escos replica
but what do we do about the brake servo pipe what used to go to the manifold. a mate said that a diesel alternator has a pump on for the vacuum but would one fit? or is there another way? the only thing i thought of would be to tap a hole in the servo end of inlet, would this be ok?
any help much apprieciated
Old Sep 7, 2008 | 05:47 PM
westus1's Avatar
westus1
alternator idea isn't a great 1 as the vacuum pump on the back requires an oil feed and a return back to the sump so would end up to much work, either tap the inlet manifold for the vacuum or do away with the servo and run a bias peddle box, but thats even more work so prob just drill and tap the manifold is easiest and best way me thinks
Old Sep 7, 2008 | 06:00 PM
BIL N KEL's Avatar
BIL N KEL
cheers dude thats what i was thinking just wondered how other people had done theirs
Old Sep 8, 2008 | 06:32 AM
Either drill a hole, or change the master cylinder for a smaller bore one, although it would then be easier, it would lengthen the travel though.
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
