PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 [109] 110 111 112 113 114
  1. Cossie Misfire
  2. amal valve question (mines unplugged)
  3. spark plugs
  4. Rear braided brake lines have they been fitted wrong? *pic*
  5. air fuel ratio's needed
  6. XR3i ABS Removal
  7. found this link
  8. Fiesta XR2i 1.8 16v MissFiring???
  9. 200 block
  10. zetec engine
  11. gear box oil
  12. 2wd sapphire cold running problems
  13. MK5 Escort Pulse Unit
  14. ESC COS ELECTRICAL MISS
  15. ESCORT COSWORTH DUMP VALVE
  16. whats needed to fit vauxhall turbo pistons to make 2.1 zetec
  17. ERST.. will not start.
  18. s2 rst!What 2 look out 4???
  19. Cossie Powersteering?
  20. Cossie cold running problems
  21. Hello All! Problem with RS Focus.
  22. head gasket question
  23. 4wd turbo
  24. Price for a clutch
  25. Paint code
  26. Rs turbo clutch question.
  27. Series 2 Idle
  28. Fitting comectic 4 layer metal headgasket ,wet or dry ?
  29. Escort hot idling/running....?.
  30. Excess Pressure in water system!!!!!!
  31. difference between L8 & P8 ecu's
  32. switchable boost/chip
  33. Focus Cosworth engine conversion?
  34. T3 or not T3
  35. oil in funny places
  36. will these alloys fit?
  37. esc cos idle
  38. Greersport??
  39. help-not starting
  40. Actuator idiot questions.
  41. escort noises and vibes....Help Please!!
  42. Miss fireing Cossie
  43. *engine mods*
  44. Zetec/FRST/Cosworth Capatibility
  45. Escort RST seat
  46. cossie hydraulic tappets
  47. Swapping over exhuast housings?
  48. When should a turbo have to be balanced?
  49. rs turbo ,doing head in
  50. head any good?
  51. What is minimum thickness allowed on 2wd cos head ?
  52. What symptoms would a faulty map sensor give?
  53. changing hub
  54. wheels
  55. Cossie 170 mph speedo into rst ?
  56. T3 Tubby
  57. DUMP VALVE PROBLEMS ON ESC COS
  58. fuel consumption 2wd saph cos
  59. Fast And Furious Oil Pressure Gauge - Wiring Help Please
  60. escos not turning over/starting
  61. Losing Oil Quickly!
  62. Exhaust housing on t3...experts views req'd
  63. Cometic headgasket - pressure in water system ?
  64. top speed nucance ! 2L zetec
  65. vibration between 50>70
  66. very loud whistling
  67. Rear diff removal hints?
  68. ZVH Turbo pistons
  69. misfire on a 4x4.. (update)
  70. Stumped.......
  71. Still Smoking :(
  72. escort cosworth dash lights
  73. cossie timing
  74. Where is the...
  75. s1 escort rs turbo ecu wiring diagram
  76. Oil temp sensor
  77. lowering a 4x4 sappy cossie?
  78. smoking saph cos
  79. Cossie - rear caliper replacement
  80. 450 bhp cossy
  81. Malfunction Indicator Light on
  82. MT 75 Gearbox
  83. focus st 170
  84. RS500 or 3 door part number
  85. 200 block parts
  86. 2.0l zetec into 16 xr2i
  87. Esc Cos probs
  88. Turbo?
  89. Escort Cosworth Boost??
  90. Will crank/rods from 205block fit into new 200 block.
  91. Scorpio TPS
  92. Air to Air
  93. Intercooling...Any benefit from added depth of Core?
  94. escos hunting
  95. Squashed exhaust problem?
  96. Cossie Mis-fire
  97. Rev Counter (2wd Saff)
  98. Twin Intercoolers Pros & Cons
  99. Oil temperature and oil pressure
  100. head skimming
  101. V6 into Transit??
  102. Intercoolers
  103. Amazinq quote for having steam seals relapced
  104. Mondeo Heater Problem
  105. GAS FLOWING
  106. Boost 25 psi one minute the 15 the other???
  107. co level
  108. Help needed on S2 Oil Pump
  109. 2wd intercooler on an erst
  110. fitting EEC IV throttle body 2wd
  111. Esc Cos ignition lights,rev counter etc not wo
  112. pinking noises from engine when turbo comes in on full accel
  113. Cossie not holding boost
  114. intercoolers
  115. Turbo Timer Yellow Relay***HELP***
  116. 1800 CVH engine. Will it fit
  117. head off or not?
  118. Zetec Turbo Head Gasket
  119. Help! ERST Problems!
  120. escort cosworth engine noise
  121. cosworth cams
  122. belt timing out??
  123. BD10 Camshaft specs?
  124. rs turbo heated seat fuse blowing(injection)
  125. Rev Counter pointing at my ABS light!!!!!!
  126. valves and pistons
  127. Fault code reader
  128. connecting AMAL valve on Escort Cosworth
  129. 2wd cos,wont start on L6,but will on L8????
  130. Headgasket blown again,advise needed.
  131. knocking cossie engine
  132. crank position sensor
  133. rocker cover change
  134. What turbo to buy? Looking for 5-600+ BHP!!!
  135. What turbo to buy? Looking for 5-600+ BHP!!!
  136. What turbo to buy? Looking for 5-600+ BHP!!!
  137. What turbo to buy? Looking for 5-600+ BHP!!!
  138. What turbo to buy? Looking for 5-600+ BHP!!!
  139. What turbo to buy? Looking for 5-600+ BHP!!!
  140. water leak!
  141. Stereo Wiring
  142. cossie 2wd timing
  143. ecu box colours 88s2 rst
  144. fiesta turbo uprated fuel pump??
  145. removed g/box today and found.........
  146. Pin me down!
  147. series II rst problem
  148. what oil for running in an engine?
  149. momo steering wheel on a S2
  150. removing the dump valve
  151. oil leaking from oil filler cap
  152. ARP flywheel bolts on escort Cosworth
  153. 2wd turbo onto 4x4?
  154. advice needed - avo coilovers
  155. Power roof fitting
  156. cud this be/worth repairing?
  157. what oil to put in gearbox
  158. what oil to put in gearbox
  159. Common problem???
  160. S2 RST knockin really easy.. look rs turbo forum.
  161. RS2K MK5 rebuilding
  162. twin rad fans
  163. injectors
  164. Starter motor
  165. whats the best pluggs ?
  166. 2wd cos fuel gauge prob
  167. NEED HELP ??????
  168. 4x4 speedo bearing needs changing
  169. Gasket or not???
  170. Exhaust Systems
  171. t5 gear ratios
  172. worthwhile upgrade for S1 to S2 breather system spec ??
  173. brooklands conversion
  174. 2WD Cooloing System
  175. competition dump valves?
  176. is a dump valve needed
  177. 1.6 zetec help needed
  178. Throttle body&tps sensor from late Escort Cosworth on L6
  179. cossie management on erst
  180. biggest wheels on a mk4?
  181. ??turbo conversion??
  182. Escort cossie cams, T4, board & chip
  183. S2 RST BHP AND OIL PROBLEMS
  184. boost problem
  185. Oil for a 4x4 Saff Cos.
  186. fresh ford fiesta
  187. rebuilt but not startin
  188. help needed
  189. dead sappier
  190. Combustion chamber volume
  191. Strange problem!
  192. missing
  193. safe psi for daily use??
  194. Escort Cosworth tracking
  195. HELP!! MY RST
  196. lightened and balanced
  197. Gearbox info needed,
  198. Gearbox info needed,
  199. RS1600i valve clearances
  200. feeling hot,hot,hot!!!
  201. feeling hot,hot,hot!!!
  202. cossie head bolts - genuine?
  203. Heated Front Screen
  204. Carbs.........
  205. more help needed plz
  206. Bolt on dash rev-meter!..help needed.a.s.a.p!
  207. Anyone using a Garrett GT28RS turbo?
  208. Rst fuel comp
  209. long studded Block ?
  210. Cooler thermostat / fan switch wanted for a Zetec
  211. does my erst need a rolling road to be set up properly.
  212. Teves ABS
  213. Group A Cambelts
  214. melted piston please help
  215. cracked block - what to do?
  216. carbon fibre wanted!
  217. help needed plz
  218. Problems Esc Cos
  219. Amal valve clickinng constantly. S2 ERST
  220. Running hot...Any Tips???
  221. help needed with clutch problem
  222. Noise from my Sierra 3d 2wd Cossie?
  223. melted piston
  224. SAMCO Hoses for ERST
  225. help idenifying a spoiler pleeese!
  226. Dump valve cutting in on Cosworth
  227. mk5/6 rs 2000 lump into mk4
  228. injectors
  229. EDIS timing check - Question?
  230. RS 500 (1988) Engine management snag (any help!)
  231. How do I convert the Zetec 1.8 & MTX75 box to MK4 Escort
  232. erst chip
  233. BAD HOT STARTING CUTTING OUT WHILE DRIVING PLEASE HELP!!!!!!
  234. zetecs?
  235. 4x4 cos blue smoke can anyone help
  236. clutch
  237. zetec/ cvh
  238. YB pistons
  239. pic request
  240. Cosworth valves for +500bhp
  241. Rattling wastegate problem
  242. Binding Brakes ? Sapph cos 4x4
  243. Is my turbo FU**ED???
  244. mobil 1 motorsport
  245. zetec-S revs - slow to settle
  246. FRST question
  247. Wiring for a S2 RS Turbo
  248. cold start probs on esc cos
  249. track(national day) help !!
  250. stem seals...how much
