Esc Cos probs
Old Jul 7, 2004 | 09:47 PM
ian rst's Avatar
ian rst
Default Esc Cos probs
Number 1
Have a grinding sort of noise coming from the near side front only does it when i back off the throttle at low speeds, well i only hear it then?
Number 2
Car seems to idle at 1500 when the car is warm and not sure why? could it be down to the crap diaphram dump valve and the crap vacuum pipe i have on it? Perhaps it has split would this lead to it idling higher?
Old Jul 9, 2004 | 07:17 PM
Cosworth4388's Avatar
Cosworth4388
m8 any air leaks would cause it to idle higher
split vac pipe or maybe plenum gasket is leaking
Old Jul 9, 2004 | 09:59 PM
ian rst's Avatar
ian rst
the idling was due to the diaphram being split.
gcfcos
59
Oct 6, 2015 05:04 PM
`spotty
Sep 25, 2015 11:41 PM
coscor86
Sep 20, 2015 01:21 PM
BigD.
Alloy wheels and ICE for sale
Sep 16, 2015 03:08 PM
gcfcos
88
Sep 15, 2015 03:48 PM
