RS2K MK5 rebuilding
Old Jun 27, 2004 | 11:38 AM
Andrei's Avatar
Andrei
Default RS2K MK5 rebuilding
RS2000---->RS Cosworth
Hi, I'm new here, and this is my first post,
and mainly it is the most important.
so, I have a Ford Escort RS2000 model 94, and I want to change the car in almost everything, I want to build an Cossie on the RS2000 Shell
First of all, IS it Possible??
so my qeustions are:
1) Is it possible?
2) If it is, what the changes need to be?
3) I'm more intrested in the YBT engine, with the bigger turbo, is it possible to fit this engine in the MKV/IV shell? again, what are the changes needed to be done?
4)a. Is it possible build an 4WD with the 3 diffrencialses on the FWD shell? the front diffrencial need to be changed?
4)b. Can I build the Cosworth with only Front Wheel Drive System, I mean the original system is need to be chaneged because of the engine position?
5) The MT75 gearbox need to be fitted here?
6)In generally, what are the parts, I need to o buy for this project? If it is possible, please, write E-V-E-R-Y-T-H-I-N-G-!!!?
7)IF SOMEONE HAVE AN ICQ PLEASE add me to his contact list with the number 234893758
Thank U everyone for the help!
BTW, if someone mean to ask why Im not preafer to buy an original Cosworth , the reason is that in my country (Israel) the is not an original ESCORT COSWORTH.
again, thank you everyone!
Old Jun 27, 2004 | 06:04 PM
Andrei's Avatar
Andrei
Someone?~
Old Jun 27, 2004 | 08:33 PM
AJ Escos's Avatar
AJ Escos
anything is possible m8 with enough work and money but to build what is basically an escort cosworth from an RS2000 is loads of work as the escos was basically built on a shortened sapphire 4x4 floorpan and is therefore very!! different to the standard escort floorpan HTH
bobsworth
77
Mar 24, 2016 09:30 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Mc5506
Oct 5, 2015 09:57 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
