escort cosworth dash lights
hi all got a prob with my dash lights on my esc cossie.
the warning lights are all working but the dash lights and boost gague lights are not. i think its the pcb inverter behind the clocks but cant be sure .
What shall i check or does anyone no where i can buy either a dash or the pcb
Any help grately appreciated.
Cant drive her at night!!!
First of all, try giving the dimmer switch a good cleaning, the track gets all crapped up!! If not bypass it with a piece of wire, then you know it's not that before you buy some new clocks or inverter!!
I'm having the same problem and I haven't found anything yet. What is the pcb inverter? Do you fog lights and high beams come on? Mine currently are not coming on and the fog ligt switch doesn't light up.
jessie_rs
11
Jun 3, 2019 04:57 PM
