Cometic headgasket - pressure in water system ?
Old Jul 12, 2004 | 08:23 AM
redracer's Avatar
redracer
Default Cometic headgasket - pressure in water system ?
Anybody that can give advice on this, is there anything else supposed to be used in conjunction with the cometic headgasket (WRC spec) as water bottle has bursted from the pressure. We have taken the head off to check the block but can find nothing wrong. After placing the head back the torque setting was increased but still the same thing ?
Anything we are doing wrong here ?
Old Jul 12, 2004 | 04:03 PM
Dave Henshall's Avatar
Dave Henshall
did you replace the thermostat and seals behind the thermostat housing?
Old Jul 14, 2004 | 08:14 PM
markk's Avatar
markk
did you put the gasket on dry ??
i would never recomend the use of a mls gasket with out applying some sort of sealer to the faces 1st as leakage can occur of oil and water
hth
mark
Old Jul 14, 2004 | 08:58 PM
Stu @ M Developments's Avatar
PassionFords Creator
Agreed.
Old Jul 15, 2004 | 07:43 AM
Dave Henshall
but the cometic ones have a slightly rubberised coating on the 2 faces which i assume will do this when its hot....?
Old Jul 15, 2004 | 04:43 PM
markk's Avatar
markk
Dave Henshall,
never ASSUME m8
all it will do is make an ASS out of U and ME !!
Old Jul 16, 2004 | 07:59 AM
Dave Henshall
correct - our first day induction told us that working on a chemical plant.
Old Sep 12, 2004 | 10:09 PM
blaazer2's Avatar
blaazer2
IS IT BOILING UP ?
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
