escort cosworth engine noise
Old Jul 2, 2004 | 02:47 PM
EscRSCos's Avatar
EscRSCos
Default escort cosworth engine noise
hi all ive got a strange engine noise coming from my escort cossie. it only happens when the car is hot and run up to temperature. plus it occours at 2000rpm its a sort of gurguling ratteling noise can anyone help.?
Old Jul 5, 2004 | 06:41 PM
joe GSM's Avatar
joe GSM
i had one on a customers car and it turned out to be pre- tensioner on the fan belt . take the belt off check the bearing also check alternator ,poweersteering pump and air con , run car without belt to see if noise has gone . regards joe
James Porter
Aug 26, 2015 10:51 PM
Old ford
Jul 31, 2015 06:50 AM
