Cossie - rear caliper replacement
Old Jul 9, 2004 | 05:46 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default Cossie - rear caliper replacement
I think my rear-left caliper has seized. Do I need to bleed the whole system to change it, or just take the old one off, put new one on and let fluid out until no bubbles ?
Old Jul 10, 2004 | 08:22 AM
frog's Avatar
frog
Old Jul 16, 2004 | 07:23 PM
frog's Avatar
frog
I am not :blonde: but I need a little help
Old Jul 18, 2004 | 04:42 PM
mike77cos's Avatar
mike77cos
I have changed the rear caliper on my 2wd saff and found that not only did I have to bleed the whole system, but I needed to use a presure bleeder to bleed the ABS. I hope this is of some help!
Old Jul 19, 2004 | 09:27 AM
frog's Avatar
frog
Thanks mike.
Does anyone have any other experience ?
Old Jul 19, 2004 | 10:01 AM
Dave Henshall's Avatar
Dave Henshall
you can just bleed it normally - as no air will have been introduced into the abs pump anyway - undo the pipe off the caliper and put a platic cap over the end.
when your new one arrives just bleed it as you would normally.
Old Jul 19, 2004 | 10:28 AM
frog's Avatar
frog
Thanks Dave, that's what I was hoping for, the workshop manual states this one should be done last, so I thought it'd be ok to just replace it, and bleed it a little to make up for the air in the caliper.
Best order one now then !
Greg
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
FlashRS
Sep 14, 2015 12:36 PM
james kiely
Aug 28, 2015 08:58 PM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
