series II rst problem
Old Jun 28, 2004 | 08:38 PM
JamesR's Avatar
JamesR
Default series II rst problem
Hi folks,
My escort seems a bit kangarooish when off the throttle and driving it.
I have only noticed this problem since i replaced the sump, it may have done it before but i only noticed it the day after i did the sump.
Could removing the sump cause these problems, if its not sealing correctly letting in air???
The sump is dry as a bone now and has no oil leaks.
Any help greatfully received, im finding it very annoying
Thanks
James
Old Jun 28, 2004 | 09:10 PM
dave green's Avatar
dave green
fitting a sump would not cause this , if it was not fitted corectly it would leak oil nothing more.
Old Jun 29, 2004 | 07:43 PM
JamesR's Avatar
JamesR
Cheers dave,
I appreciate that mate.
I will lok into other things
Old Jun 29, 2004 | 09:07 PM
Stu @ M Developments's Avatar
PassionFords Creator
Sorry Dave, but thats not quite right...
Bosch KE utilises a closed loop crankcase vent system and constantly draws air from within the crankcase / breathers. Think what happens if you remove the filler cap...
Maybe you had a leak before and now youve fixed it the engine is running excessively rich... get her to a pro for checking over is best advice i can give if shes deffo airtight now.
JK12
33
Apr 26, 2021 12:09 PM
Chas
Oct 5, 2015 07:13 PM
`spotty
Sep 25, 2015 11:41 PM
Billy_RS
Sep 13, 2015 04:17 PM
Bransby
Sep 11, 2015 01:09 AM
