head any good?
Old Jul 12, 2004 | 08:35 PM
se mk3 cabbie's Avatar
se mk3 cabbie
Default head any good?
just stripped an engine that was knocking from an xr3 cab, took off head and it has had a fair bit of work done such as 3 angled valve seats adjustable tappets, ports are huge, double valve springs etc, need to know if will be any good on a turbo or not due to combustion chamber and valve clearances etc
Old Aug 3, 2004 | 07:09 PM
se mk3 cabbie
so know one can help then, surely someone out there can help PLEASE
Old Aug 4, 2004 | 07:47 AM
JesseT's Avatar
JesseT
The turbo head is the same head as any XR3/XR3i head, so it should fit nicely. You should anyhow investigate the cam, cam wheel, and amount skimmed so you better know what you can use.
BTW, as far as I know, any CVH head has 3 angle valve seats as standard. At least for the inlet side. Of course these still are not race type seats.
markk
Dec 2, 2021 06:59 PM
3i Jim
Nov 20, 2015 05:12 AM
turbotrev
Aug 22, 2015 11:41 AM
salsheikh
Alloy wheels and ICE for sale
Aug 20, 2015 12:33 PM
salsheikh
Jul 30, 2015 08:45 PM
