Miss fireing Cossie
Old Jul 13, 2004 | 01:24 PM
STEG_3dr's Avatar
STEG_3dr
Default Miss fireing Cossie
Hi
I have recently had a my engine re-built, which was running fine, but now I think it has picked up some electrical fault, causing the car to miss fire, The miss fire is intermittent and seems to do it either when you are driving without using any load on the engine, or slightly letting off the acceleration when cruising.
Has any one else seen this fault or have any ideas what would be causing it.
cheeRS for any help.
Steg
Old Jul 13, 2004 | 06:05 PM
Mechanic_Wedgie's Avatar
Mechanic_Wedgie
Seems to be the same problem I had, my problem was the phase-sensor (inside the distributer) .
I bought a new one an fitted it and no more misfire's.
greetz
Old Jul 14, 2004 | 05:51 PM
STEG_3dr's Avatar
STEG_3dr
Cheers Tweet
The Phase-sensor has only recently been changed about 800 miles ago and the problem started about 300 miles ago, do these normaly fail?
Any other help would be great as im off to the nurburgring in 3 weeks.
Steg
Old Jul 14, 2004 | 07:43 PM
Mechanic_Wedgie
Is the clearance of the phase sensor set right, it must be between 0.2 and 0.3 mm.
gambo08
Feb 4, 2016 10:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Fil
Sep 30, 2015 12:08 PM
cossie330
Sep 27, 2015 04:13 PM
