HELP!! MY RST
Old Jun 19, 2004 | 12:55 AM
rabmc's Avatar
rabmc
Default HELP!! MY RST
Out in my rs turbo tonight , the engine spec is ,grs intercooler,bayoo chip,piper cam and pulley , all rebuilt 8000 miles or so ago anyway , my car runs perfect (usually) nut a mouse fart out the engine ,car runs 15 psi and made 158 bhp @wheels and is set up ,fueling is all sound ,, and raced a astra turbo tonight and was sitting at 135 ish and engine revs started to die on me basically engine was losing power and i new something was up pulled over and stoped engine as was struggling to keep running popped bonnet and my oil cap had blew off resulting in some oil over my rocker cover , cleaned up and checked oil etc, all ok but when tried to start again , sounded as if was running on 3 cylinders and was smoking out my exzaust pretty bad anyway toed it home and going to get engine apart on sunday engine starts but struggles bad , sounds not to bad , but has a real reek of smoke when running to cap it off my girlfriend told me she stuck a £10 worth of normal unleaded in it this was set up to run super! has this been the factor in my engine blowing? whtat uz think damage is? what uz recommend buying ? any help appreciated
Old Jun 19, 2004 | 03:34 AM
Stu @ M Developments's Avatar
PassionFords Creator
rabmcS2,
Im afraid youve probably melted 1 or more pistons then, which usually results in a pretty comprehensive rebuild. sorry.
Old Jun 19, 2004 | 06:20 AM
rabmc's Avatar
rabmc
Cheerz stu am not mechanical minded at all , but whats the best thing in ur opinion to do , replace pistons/low comps ? whats the process i.e changing other stuff while doing it , not got a great deal to spend but will fix, and want it beefed up slightly , but not going madd, ahhh wish i hadnt turned on to bypass now , cheerz m8.. rab , ohh and in doghouse now , because i said a few choice words to my girlfriend
Old Jun 19, 2004 | 05:21 PM
Turbo Thompson's Avatar
Turbo Thompson
sounds like back pressure to me mate, Stu is bang on with what he thinks.
Old Jun 20, 2004 | 12:48 PM
davidreader5's Avatar
davidreader5
HI,
Crankcase pressure obviously, and at the pace you were going
sounds like piston or rings, before u strip the motor do a compression test
to confirm damage, if comp test good check your breather system is clear,
as RS turbo's wont run well with oilcap off should stop running, or run lumpy
when warm,
Dave.
Old Jun 20, 2004 | 01:41 PM
rabmc's Avatar
rabmc
Cheerz guys will , do ,, gettin in about my engine bout tea time to see damage ,is this a dreammm
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
`spotty
Sep 25, 2015 11:41 PM
Billy_RS
Sep 13, 2015 04:17 PM
