Cossie Misfire
Old Jul 18, 2004 | 07:05 PM
Sticky.'s Avatar
Sticky.
Default Cossie Misfire
2wd totally standard cossie, with a misfire, when the car is ticking over, number 1 & 3 plug are getting wet. Ive changed the injectors round incase it was a weeping inj, Ive changed the leads & plugs & its still doing the same
Any idea folks, as ive spent all day trying to fix it & im running out of ideas now
Could it be the cooling temp sensor or Map sensor
Old Jul 19, 2004 | 07:37 AM
Sticky.'s Avatar
Sticky.
Old Jul 19, 2004 | 12:16 PM
Sticky.'s Avatar
Sticky.
Someone must have an idea
Ive just changed the cooling temp sensor & air charge, but still the same
Ive checked the crank sensor for the gap etc, & thats ok.
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
