switchable boost/chip
Old Jul 14, 2004 | 05:54 PM
avengerpenguin's Avatar
avengerpenguin
Default switchable boost/chip
A few years ago I met a guy who had a 2wd saff, we went out running standard trim, and then he had a switch on the centre consol that he claimed switched iit to a stage one chip. is this possible? Does anyone know how to do it
Old Jul 14, 2004 | 08:59 PM
Stu @ M Developments's Avatar
PassionFords Creator
Yes and yes mate. No problem at all.
Old Jul 15, 2004 | 01:36 AM
richm's Avatar
richm
as Stu says... at a lesser level, I had the same arrangement in a Cavalier a while back..
Old Jul 15, 2004 | 05:25 AM
avengerpenguin
stu, what sort of price would I be looking at? Is it a lot more that a normal chip upgrade
Old Jul 15, 2004 | 07:00 AM
depends how you want to do it to be honest......
I suspect that he had a simple two stage boost switch fitted and if so, no more than Ł50 fitted id expect...
If he really did have a map switch then on a cossie thats Ł200 plus the cost of your two maps and installation of tyhe dash switch. We can incorporate your own 2 maps into the chip if required. Generally speaking, the only cars likely to actually require this are cars with a seperate map for high octane race fuel or a car running a dry nos system. The maps can be switched live as well.
But its there if you need it.
Old Jul 19, 2004 | 03:46 PM
s1 cabby's Avatar
s1 cabby
I had a 2 stage boost set up in my old rs basically it was just a switch in the negetive feed from the amal valve, with it off it was set up via the actuator then when you flicked the switch the amal valve kicked it in and it ran more boost!!!
Obviously the fueling doesnt get affected this way hence why i never use it anyway
cossytonyt
Nov 3, 2012 01:45 PM
big_wig_074
Feb 20, 2011 08:03 PM
Stavros
Dec 23, 2004 07:14 PM
