PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 [114]
  1. Injection
  2. T3 Upgrade...
  3. oilplug size
  4. AIR INJECTORS
  5. Ford TIS software upgrades.
  6. is it chipped
  7. PISTON RINGS
  8. Carbs
  9. Eibach or Apex?
  10. whats the biggest brakes..
  11. fitting a rev counter to a mk4 1.8 diesel...
  12. Twin plate clutch for fwd escort?
  13. Can you fit 4 pot calipers to any disc?
  14. turbo not spinning
  15. Intermittent Miss!!!!
  16. cossie running prob??
  17. Rev limit of standard 4x4 cossie?
  18. car stalled then revved like crazy at 2000-4000 rpm
  19. Cossie Mangement Q
  20. 1600 CVH Loosing Oil
  21. S1 gearbox rebuild Help please!
  22. What exactly is Diesel Knock
  23. lookin for a new car...
  24. Strange problem/good garages
  25. 205 or 200 block confusion ????????????
  26. Which injectors ???
  27. Heater and Indicators ERST 90 spec
  28. help
  29. Working electric windows with ignition off
  30. missing under load
  31. Tyre pressures for an Escort Cosworth with 18" wheels??
  32. FRST and RST turbo question
  33. Series 1 poor help 4 year old problem!!!!!!!!
  34. cvh rockers
  35. Spring rates for front of 2WD Sapphire Cosworth
  36. Running Flat
  37. S2 Pump, buzzin VLoud, cutting out hesitating
  38. Big Wing Sump
  39. zvh conversions help!!!!!!!!!!!!!!!!!!!!!!!!! asap
  40. Esc S2 Blown head gasket, help!!
  41. b&m quickshift problem
  42. b&m quickshift problem
  43. what ACT is best on cossie?
  44. COSSIE....WHATS THE BEST WAY 2 UP THE BHP????????????????
  45. s2 question
  46. S1 Runs on 3 cylinders ?
  47. how much oil in a s2 box?
  48. lost boost presure
  49. Excessive Turbo Heat
  50. Standard T3 Turbo's V's Hybrid T3's........
  51. Esc cos elekron valve question(problem fixed)
  52. Not holding boost??? Weird?
  53. Carb for 1.6 Orion (1988)
  54. 16V Zetec Turbo in Fiesta - clearance between turbo and Rad?
  55. Koni front struts
  56. Tyre jump on lowered car
  57. Heated Front Screen relay ?
  58. cossie 4x4 intercooler on a series 2 rs turbo????????????
  59. Is it possible to long stud all the head bolt holes on a cos
  60. XR2i rev counter
  61. Noisy-ass Cossie engine
  62. Pro's & Con's of Decambering rear of 3door Cossie????
  63. Is this breather set up correct (pics)
  64. sapphire 2wd braking problem
  65. Bodywork (spray job)
  66. T34 .63 housings
  67. WILLTHIS RAD FIT MY ESCORT COS BIG TURBO
  68. Escort cos front driveshafts.
  69. F.A.O STU
  70. Longer wheel studs on 3 door???
  71. Anodised alloy????
  72. Head flow rate
  73. ESCORT MK1 COSSIE TRANSPLANT
  74. How to up rev limit on cossie managed S2???
  75. super chargers?
  76. Removing injecotors off efi fuel rail?
  77. Escort1.6i 16v into 1.6rst??????
  78. Damn headrests
  79. cvh efi prob, juddering when warm,help please!!
  80. cossie bottom end
  81. CVH Carb Q
  82. Fiesta Si (steering)
  83. What plug do the 400+hp anti-lag guys run?
  84. T28 BOOST PROBLEM
  85. Haeter Matrix and Fan switch
  86. What is the correct procedure for timing a cossy ? ? ?
  87. std s2 gearbox, how much power can it take?
  88. Running warm in s2
  89. 3/door/xr4i spoiler caps?
  90. koni shox
  91. 2wd cossie cooler on s2
  92. Boost for stage 1
  93. Cossie still overheating!!
  94. How does a turbo increase power!?
  95. 4x4 pistons into 2wd engine?
  96. What Brake Servo and Master Cylinder ?
  97. Help power steering noise loud on Saph Cos!
  98. Is it possible to run 8 greens on a standerd L8 ecu
  99. S2 erst cutting out.
  100. Sierra cossie reverse lights won't come on :(
  101. FAO zetec turbo/ZVH peeps: Turboing a zetec advice please
  102. CAMS
  103. no spark
  104. misfire on 2wd saph
  105. ACRALITE PISTONS
  106. Oil on clutch
  107. escort rs turbo -31 actuator the same as a 2wd cosworth -31?
  108. clifford alarm
  109. Cossie overheating :(
  110. help needed please
  111. braking problem s2 erst
  112. Splitters
  113. s2 boost problem please help
  114. S2 EFI conversion
  115. Lip at the top of cylinder bores? HELP needed
  116. Rear Crank Oil Seal?
  117. N/A Cosworth
  118. cometic headgaskets
  119. Boost problem guys
  120. very slight misfire - saff
  121. PISTON QUESTION
  122. cometic headgaskets standard headbolts or stud nut kit
  123. steering problem
  124. Low comp? Opinions please!
  125. my erst
  126. 2wd backboxes
  127. should I run a T4 with amal valve
  128. CVH Cossy Management.
  129. anyone with a quickshift
  130. Meo Valve
  131. brake bleeding on an s2
  132. Escort S2 fuse box???
  133. f.a.o. Stu @ msd
  134. Cant get spark, on cossie management
  135. SECS Monitor installation instruction????
  136. crankshaft needle roller bearing
  137. escort turbo diesel -advice needed
  138. escort turbo conversion
  139. Quaife or not?
  140. Brake-servo Taunus/cortina mk3
  141. TPS sensor
  142. Sapphire's 4 little fookin buttons on the dash
  143. HEAD BOLTS
  144. Thermostat
  145. rolling radius of tyres plz
  146. ARE CAMBELT COVERS THE SAME ?
  147. ARE CAM COVERS THE SAME ?
  148. anyone ??
  149. Group A gearbox by Getrag, anyone know the details?
  150. what is the boost level in a standard 4x4 saff cossie?
  151. Cossie Turbo problem
  152. TUNERS, please read and help me.
  153. how much boost?
  154. help please - UPDATED!!! MORE HELP NEEDED ASAP!!!!!!
  155. Help with 3dr hatch light
  156. Temp sensor and AFR sensor
  157. saph cossie samcos
  158. Help pls!!!Rear caliper Piston!!
  159. Arrrgh New cossie cut out on me this morning *update*
  160. Changing throttle body dia... remap?
  161. Just went for a drive and had a problem!!
  162. cams
  163. 4x4 cossie head question
  164. Cosworth has a mind of it's own!
  165. Honing bores
  166. Old School Techie Question re: Dwell Angle
  167. Another techy Q to get the essays out!?
  168. Cossie crank
  169. hesitating Cossie
  170. difficulty starting s2 rst
  171. valves in the head 4W/D COSSIE "QUESTION"
  172. rear brake disks
  173. cossie cutting out!!!
  174. Cossie keeps eating
  175. crankshaft sensor bracket for cozzie management on rst
  176. Anybody done a 330 conversion themselves???
  177. 2WD manifold on a 4x4, what do i need???
  178. Amal Valve Jetting.....Why When and How???
  179. stange noise from back of cossie
  180. Cosworth Big Wing Sumps - How best to do them ???
  181. 2wd or 4x4 intercooler ?
  182. ERST Cold Start valve and thermo Time Switch
  183. Help poss map sensor fault.
  184. Boost problems....???
  185. PROBLEM WITH RST S2 GEARBOX, PLEASE HELP!!!
  186. Overboosting @ 14PSI ????
  187. Escos dash in a mk4
  188. what causes a head to go porous?
  189. Idel
  190. RST metering unit help....
  191. Cossie Inlet Valves
  192. TAPPETS ON A MK4 ESCORT
  193. s2 popping and banging on boost
  194. Prob with cabriolet hood
  195. oil pressure problems
  196. water in the turbo
  197. ngk 9 gap setting
  198. noise pissing me off
  199. funny gas smell PLEASE HELP
  200. s2 fuel pump realy burning out
  201. Air Leak or Fueling
  202. erst help please
  203. No battery light in s2 dash????
  204. Misfiring Mondeo
  205. Hybrid T3 vs Hybrid T34??????
  206. HELP MK 3 Fezzy rear wiper
  207. run then misfire and dies
  208. cossie ecu's
  209. Early saph dash into a 3door
  210. Orion mfi keeps losing water
  211. Escort Cossie Alloys on an S1 RST
  212. Which disks for S2 to Cossie front upgrade
  213. fitting an electronic boost computer
  214. Fiesta turbo in an escort?
  215. cossie bearing shells
  216. Do you really know about the cvh?
  217. Help please
  218. Oil coming from Dump valve
  219. FAN SWITCH ESCORT COS
  220. Cossie cooler on a series 1 anybody?????
  221. This is a good 1 for you!!!!
  222. oil coming from breather pipe
  223. Error Code 1+2 Sapph 4x4.......???
  224. cossy managment on S2 (timing)
  225. Fiesta RS Turbo gear selection problem.
  226. cossie 2wd standard head and piston specs
