Not holding boost??? Weird?
Old Dec 6, 2003 | 05:15 PM
MarK4's Avatar
MarK4
Default Not holding boost??? Weird?
Right got a weird problem.
My car should hold 22psi....Obviously you don't normally get full boost in 1st and 2nd due to there not been enough load...In 3rd and 4th it hits 22psi then drops to as low as 16-17 but in 5th it hits and holds 22? My actuator is wound in so much tht some of the shaft has been cut off.
Turbo is a stage 3 (.48) and seems in perfect woking order and to my knoledge there are no air leaks..
Any ideas???
Old Dec 7, 2003 | 12:14 AM
PJay's Avatar
PJay
If it's holdng 22 in 5th then it should be ok mate, you'll probably find that it holds it in 4th too when under load and your car would have had the boost set in 4th on the rollers, all is ok if you ask me mate, don't worry about ti too much as it'll need a setup when it's been mapped properly
PJay
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
