my erst
Old Nov 21, 2003 | 08:55 AM
Default my erst
hi, recently i was having probs with my series 2. car was cutting out, overbooting, dump-valve not working/over fueling.
it turnt out all it was, was a knackered DV. Now what i have done it taken the dv off and tempory blocked up the pipe.Now since i have done this my car is running really well, no longer do i have to warm the engine for ages in the morning for it not to cut out. Im abit confussed?
could you tell me why this happens, as now im in two minds whether to get another dv.
or did i have the previous dv wired wrong, it was ran into the inlet manifold, and then t-peice to the ecu(i think, im not too hot on cars)
also what is the best dv to get(thats if u suggest to get one)
thanks
Old Nov 21, 2003 | 04:00 PM
Markb_s1's Avatar
Markb_s1
Dunno what the deal is with the dump valve, althogh if you have a non piston type and it's knackered i know it can lead to problems with idle/stalling due to an air leak.
your dump valve should sit somewhere between the exit form the intercooler and the inlet manifold, and the small vacuum hose generally goes to a vacuum pipe leading from one of the point on top of the inlet manifold.
Piston type dump vavle is the only type to run if you're on MFI as diaphragm type causes the above mentioned problems. Bailey sell them and i think forge do too.
HTH>
Mark.
Mc5506
Oct 5, 2015 09:57 PM
beller
Sep 21, 2015 04:13 AM
Ellsa
Aug 9, 2015 07:03 PM
Dirty Harry
Trader Parts for Sale.
Feb 3, 2004 06:39 PM
mot
Jan 17, 2004 01:24 PM
