Help poss map sensor fault.
Old Oct 11, 2003 | 06:42 AM
simonc's Avatar
simonc
Default Help poss map sensor fault.
When refilling expansion bottle after changing radiator I accidently soaked the map sensor (3 bar on 3dr cos), now won't idle properly & runs like a dog below about 2500 & on light throttle,ok when driving on boost. Suspected map sensor so substituted for standard 2bar (only spare I had) & now it idles perfect & runs smooth again. Has anyone else had this problem, is it worth me trying to dry out 3bar or do you think I need a new one,if so does anyone know who's got any 3bars as I've heard these are hard to get hold of.
Cheers , Simon.
Old Oct 11, 2003 | 09:39 AM
Stu @ M Developments's Avatar
PassionFords Creator
Dry it out thoroughly and it should be ok. They are pretty water resistant so its more likely the electrical connector you have drenched.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
