Fiesta turbo in an escort?
Has any1 fitted a FRST efi engine into a mk4 escort ? im hoping to do it later this month and would like to know if there are any pionts to look out for.Any advice would be appriceated,Thanks
Loads have but I aint one of them
I think most people prefer to upgrade their RS Escort engines from MFi to EFi from the Fiesta however as it is a better system with more tuning potential.
Bigger injectors etc
Im only going down the FRST road coz my 3i has an EFI engine and ive been offered the fiesta lump and all ancilliarys at a very reasonable price otherwise i would have gone for the ERST
Basically how much of the loom do i need to remove/replace (im told its a fairly small piece)and will a std ERST zorst still fit or do i need to get 1 made?
thanks
thanks
standerd exhaust will fit if you use a t3 turbo as per erst setup, with mine the loom was for a ofac system and all i had to do was remove pin 2 (i think ) from the edis sensor and swap something like pin 8 with 22 on the ecu. very easy really just looking at two wiring diagrams for both vechiles and that was it.
thanks
oriont
thanks
oriont
muz
16-08-2015 12:57 PM
