Removing injecotors off efi fuel rail?
I have removed the fiesta efi fuel rail off the inlet and the injectors are sitting in the rail. How do you remove them?? unscrew? didn't want to start yanking them about incase I broke something lol...
Also do the 2wd yellows flow exactly the same as the 4x4 blues? I thought they did but someone told me blues flow better up top
Thanks in advance
Thanks in advance
The injectors are held in place just by o-rings, so just pull them out. I've also seen identical figures given for the yellow and blue injectors, but heard they are not totally identical. Would be interesting to know because I'm using blues in my setup.
