Cossie Inlet Valves
Old Oct 6, 2003 | 07:05 PM
northerner's Avatar
northerner
Default Cossie Inlet Valves
After speaking to someone today regarding inlet valves, they are under the impression that the original cosworth inlet valves were sodium filled and the aftermarket ones are stainless steel.
If they are different, is it worth paying for the sodium ones?
Old Oct 6, 2003 | 08:25 PM
richm's Avatar
richm
Exhaust valves are sodium filled, inlets are solid IIRC
Yes, the sodium exhausts are necessary (and expensive )
Old Oct 6, 2003 | 08:43 PM
Toe Knee's Avatar
Toe Knee
As above, think their all the same. Would only go for genuine cossie ones unless your going for bigger inlet!
Old Oct 7, 2003 | 06:57 AM
northerner's Avatar
northerner
I knew that the exhaust valves were sodium filled for better heat dispitation, but thought that the inlet valves were solid stainless steel.
Old Oct 7, 2003 | 07:23 AM
richm's Avatar
richm
northerner,
yes you are correct.
Not sure if standard inlets are technically 'stainless' steel, but solid yes.
Valves are generally nickel alloy rather than stainless IIRC
cos elle
Sep 25, 2015 09:52 AM
xrmalin
Sep 13, 2015 06:52 PM
Chopshop85
Sep 12, 2015 06:42 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
cossirob
Sep 3, 2015 09:17 PM
