What exactly is Diesel Knock
Old Dec 11, 2003 | 10:22 AM
Mike Gurney's Avatar
Mike Gurney
Default What exactly is Diesel Knock
On startup when a diesel is cold
why do they knock - is it like pre ignition ?
Old Dec 11, 2003 | 12:31 PM
JesseT's Avatar
JesseT
The whole concept of a Diesel engine is based on pre ignition, in a way at least. Could it just be piston slap?
Old Dec 12, 2003 | 03:18 PM
Mike Gurney
bttt
Old Dec 12, 2003 | 05:22 PM
Default Re: What exactly is Diesel Knock
let me try : the higher the temperature of the diesel,the easier it is to self-ignite it. when the engine (cilinder/piston) is cold it will take longer for the mixture to reach the 'self-ignition-temperature'. in other words , the piston has to travel further up the cilinder in order to get the mixture to ignite( more compression=higher temperature)
hope this helps..
tankybaby66
Feb 6, 2016 02:24 PM
Fiddy
21
Sep 29, 2015 06:10 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
Bighandsuk
Sep 2, 2015 05:23 PM
