Escort Cossie Alloys on an S1 RST
B83 YKM
Can you fit Escort Cossie wheels onto a S1 RST? If so, what mods are required to get them to fit? Has anyone managed to do it in the past?
Please help!!!
Please help!!!
esc cos alloys are to wide unless u want to grind ur arches and trim the kit, not sure if they will foul the shocks, seen some on a frst and it took lots of grinding and trimming of the kit, also it needed coil overs and they still rubbed the arches now and again, best idea is to get the 16 in mondeo si ones, there the same but arent as wide , had them my old s2, all i had to do was bend the front arch lip up very slightly, the rears were fine and the car was lowered 25mm, u need 205, 45 16 tyres though
hope this helps, cheers sm
