how much oil in a s2 box?
anyone know how much oil ur supposed to put in a s2 gearbox?
haynes manual says 3.1 litres and halfords gearbox oil index says 2.1 litres
i dont want to under or overfill the box and knacker it
cheers sm
cheers sm
get the car level, open the filler plug . add oil till it just reaches the threads of the plug .
Job done ! 3 litres for a empty box sounds about right .
3 liters is spot on. After 3.5 the oil starts to pour out of the filling hole, which is a bit too much. 3.1 is the amount the manual gives for all BC gearboxes, but then again the LSD doesn't take much oil in it to the standard differential.
TPM961
15-01-2018 10:50 AM
