PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114
  1. Fiesta Idling problem
  2. Convers+ & entertainment system gremlins please help
  3. 2L zetec turbo build
  4. What fuel pressure reg for Billet fuel rail
  5. Escort Cosworth ST cutout
  6. ecu location?
  7. Cometic water pump gasket
  8. Changing the engine of a fiesta
  9. 3.0 V6 AJ Engine mystery...
  10. Please I need help
  11. Rattle noise from engine. Focus 02 1.6 auto
  12. Focus air intake hose and ABS light
  13. 1.6 ecoboost in mk6 fiesta
  14. Fault code sheet EEC IV T25 escort cosworth
  15. 2wd saff stg 1 not reving past 5000rpm
  16. Camshaft question
  17. Focus RS alloy on Sapp...?
  18. Diagnsotic plug t25 cosworth.
  19. Help back smoke ford focus 2.0 turbo diesel
  20. Transit connect won't start
  21. Wipers not working at all?
  22. Misfiring for first 20 seconds?!
  23. Fuel tank strap part number sapphire 4x4 needed
  24. Green steel brake pipe
  25. Zetec Microsquirt disaster
  26. 90 Spec EFi Fuel tank sender
  27. 2wd rear brake pads different to 4x4 pads
  28. Sierra saphire glsi boa conversion
  29. Speed Cameras on Ford Sat Nav
  30. Focus Quarterlight fitting
  31. mk1 focus temp gauge erratic overheat HELP PLZ
  32. Mk4 escort headlight lower ball clip
  33. St170 turbo
  34. transit diesel randomly cuts out.
  35. 05 fiesta st rev hang when cold/ rough idle when warm
  36. Turbo radiator cooler are they worth while?
  37. Engine oil leak on my Dax Rush Cosworth
  38. Mondeo mk4 1.8 con rod torque settings
  39. focus cly head temp sensor? help please
  40. Mk4 escort cabriolet electric windows not working gggrrr
  41. Help for tuning a focus 1.6 tdci
  42. Temputure coolant sensor
  43. Cosworth std conrod length
  44. Turbo Damper Bracket For 4x4 Head
  45. mondeo st200 help needed
  46. Coolant plumbing help please
  47. Mondeo mk4 tyre pressure system
  48. Emerald K6 ST170
  49. blanking egr
  50. Ford Fiesta 2004 1.4 to 1.6 engine swap
  51. Driveshaft
  52. Staggered wheel sizes on Cossie 4x4
  53. Please help
  54. Wits end. Streetka battery light.
  55. My Ford Fiesta using loads of fuel
  56. Knocking
  57. Tial dump valve spring
  58. ARP head Bolts
  59. floppy clutch
  60. Cmax battery light comes on
  61. 2wd cossie gear knob thread size?
  62. Door card speaker holes
  63. brakes applied saff turns right update of the update of the update
  64. master cylinder/abs problems bleeding
  65. How to lower the compression on a st170
  66. saff 2wd brake master cylinder
  67. transit connect drivers seat
  68. brakes applied saff turns right update of the update
  69. Rs Turbo AMAL piping problem!!
  70. Ford finesse 1.3
  71. Propshaft donut
  72. Mk6 Fiesta wheel fitment
  73. Focus 1.6 2009
  74. Cosworth Starting Problem
  75. Help Ib5 rebuild problems
  76. Ford Focus MK2 Titanium - Right driver side vent not blowing any air
  77. Xr2 zvh questions
  78. Mk4 Mondeo Powershift gearbox damage
  79. 2wd saff centre bearing
  80. brake pressure reduceing valve leaking saff 2wd
  81. Which 4 spd Gearbox options for Xr3i engine ?
  82. brakes applied saff wants to turn right update
  83. Series 1 Metering head issue
  84. escort mk6 head light conversion
  85. Eprom checksum error
  86. billet crank pulley and 36-1 pick up
  87. 06 ranger tdci
  88. 88 orion sticking caliper
  89. escort zetec to fiesta clutch update
  90. 1998 fiesta to escort zetec which clutch
  91. brakes applied saff wants to turn right
  92. Focus mk3 leaving white spots on drive
  93. Chirpy sound under the bonnet (Puma)
  94. Car's wipers, radio, lights, speedometer, and fuel gauge turning off
  95. ECU tunning
  96. Need help
  97. focus mk1 rear spring remove/refit?
  98. Wenny replaced doughnut with UJ
  99. 1.6 cvh mfi, what is this circled on throttle?
  100. sorry newbie ere
  101. cossie GGR rear diff mount query
  102. fuel pump relay re wire help please 2wd saff
  103. Which DTA managment ?
  104. Centre bearing for rear prop shaft cos 4x4 needed
  105. zetec ecu pin outs
  106. fuel gauge
  107. Cossie dashboard fittment.
  108. Clutch Bleeding
  109. L8 / P8 Cosworth ECU repair??
  110. Catastrophe
  111. Zetec turbo management?
  112. 1.6 cvh mfi c0
  113. Zetec on 32/36 carb
  114. Geometry 3mm toe IN
  115. spark plug gap with group A coil
  116. Please help !!!!Fiesta rs turbo ofab wont start no injector pulse on cranking
  117. Billet rear hubs Cossie 4x4
  118. Sierra Steering arms compatability
  119. Engine conversion
  120. Reyland hydraulic clutch conversion
  121. What Spark plugs 430+ bhp with msd waisted spark
  122. Hi there good evening I have a question I have a small pipe at the back of my mondeo
  123. St170 cam bearing caps onto blacktop head?
  124. 2.0 Pinto. not running right
  125. Zetec turbo external wastegate
  126. fuel pressure problem fiesta turbo
  127. Escort mk1 1974
  128. compression ratio for supercharged xr4i
  129. Series 1 rs turbo body kit?
  130. Mercur xr4ti windows
  131. Rwd zetec turbo
  132. do i need my dump valve
  133. High Speed misfire
  134. do i need my dump vaive
  135. Zetec silvertop coil
  136. fitting new saff 2wd cv joints
  137. saff 2wd rear hub nuts
  138. 2wd saff cv joints
  139. Boost problems
  140. High RPM when shifting gears....
  141. good quality gaskets for 2.8 mfi
  142. Ka battery reading zero on multimeter
  143. Cossie Alternator wiring HELP
  144. Mk1 granada
  145. mk1 fiesta blacktop to st170 swap
  146. Accelerator pedal
  147. mk1 focus clutch bleeder access
  148. misfire
  149. Battery isolator
  150. Xr2 rs turbo fuel problems
  151. Recurculation valve focus st 225 mk2
  152. Mk3 Mondeo questions (electrical)
  153. DPF problems
  154. 2wd saph rev counter
  155. PF01 Replacement or alternative?
  156. St170 clocks
  157. Compbrake diske thickness..?
  158. pinto spitting through carbs
  159. Ford Fusion 2003 1.4 decat manifolds
  160. 24V Sierra conversion questions
  161. 2002 Transit t260 2.0 starting issues
  162. boost control solenoid
  163. CVH 1.3 head versus 1.6 head
  164. Will a blacktop zetec go straight into a mk1 focus rs ?
  165. Mk4 Fiesta/Puma 1.7
  166. MK1 Kuga seat wiring loom
  167. Sierra Front Diff Deferences
  168. Sierra cosworth fans not working
  169. cosworth managed cvh cold start
  170. Weber 32/36 jets for 1.4 endura
  171. 4x4 FRont cross member
  172. RS 500 ECU cover
  173. transmission Malfunction
  174. Fuse identification
  175. how to reduce caster sierra H14 ARB?
  176. Fiesta st 2.0 duratec air con delete
  177. Ford KA Ambient Air Sensor Replacement
  178. Escort mk2 breaks
  179. Pectel T2 to EEC-V
  180. is the battery dead?
  181. Transit Custom Euro 6
  182. Parts needed for 2.0 blacktop zetec turbo in mk4 escort
  183. Non ford (peugeot boxer) question.
  184. D4162T Diesel issue
  185. Strange Fuel Delivery Problem
  186. ford focus 1.8 to 1.6 is it possible and what would i need?
  187. Need some help on my ranger
  188. Engine Malfunction light... yet drives like a dream
  189. Turning zetec bottom end by hand
  190. ST170 VVT tables
  191. 1.3 endura e fan not working
  192. Duratec he bolt pattern
  193. 4x4 front diff bearing
  194. Rs spoiler
  195. Xr3i MFI running issues again and again and again!
  196. P0 2E1 code
  197. Best 'road use' oil for Getrag grp A g/box.
  198. fiesta mk 6 airbag light
  199. Will someone listen to my turbo, please?
  200. Group a Coil Rewire Loom
  201. Clutch Release Arm
  202. Arp cam bolts
  203. CVH Engines
  204. BD16 cams.
  205. 2.0 zetec turbo clutch choice mines goosed
  206. Rs2000 into my mk4 kombi
  207. Conversion
  208. Starting issue on my s2.
  209. Fuel pressure dropping off
  210. Escort M3 Zetec - Running Issues, Please Help...
  211. Question about CAT's on sierra sapphire 4x4 & engine type
  212. 2.1 zetec turbo help?
  213. Couple of questions about cossie problems
  214. Duratec transplant question
  215. fiesta endura e tappet settings
  216. A/c climate control
  217. turbo play
  218. Spare key
  219. RST cuts out after 5 secs
  220. Driving license towing and van restrictions
  221. Cosworth T25 GGR 305 chip trubble. Need some help please.
  222. Sapphire cosworth Group a steering shaft
  223. Escort Turbo RS - TurboCharger
  224. MK2 focus RS Which brand is the best heavy duty boost solenoid??
  225. leaking valve
  226. Fitted ST170 Alloys to 1999 Focus Ghia - rubbing
  227. zebec se oil issues, excessive rocker pressure
  228. Help with I.D. on my zetec cams please.
  229. Omex 600 Start Issues
  230. Escort to Saxo electric power steering conversion help
  231. Kp racing pistons
  232. Cosworth Rev counter not working
  233. Cosworth Cutting out when cold!!
  234. Ignition problem solving
  235. ST170 engine into MK3 Escort
  236. Petel T6 update
  237. steering wheel
  238. cosworth 4x4 front diff
  239. Powerchips monitor
  240. Fiesta 2014 Air Con drain
  241. Fiesta Zetec s cvh turbo conversion
  242. MK3 Fiesta engine swap
  243. Sierra -91 4x4 rear diff swap and ratio question
  244. ford scorpio 2.9 auto to maunal ???
  245. Sierra DOHC throttle cable replacement
  246. Who's best to rebuild a Garrett gt3076r ?
  247. Supreme unleaded/high octane fuels. Any difference?
  248. Escos rev counter playing up
  249. Zetec Turbo build HELP!!!
  250. Upgrading to cosworth powered brake pump help
