- Flickering oil light on fiesta tddi,please help!!
- Rough Boosting Saph...
- ka engine problems
- water in oil tank
- escort van stals
- Gearbox fitment
- Paul Mee
- Zetec Problems!
- Is my boost gauge broken
- Frs heater resistor pack fails again
- fiesta 1.4 16v r reg non starter
- fuse box???
- cosworth engine noise
- s reg van 55 weight
- x reg escort deisel van advice
- what the blinking flip is a tps?
- KA Engine Management Light
- gartrac re-build. finally
- no ignition power...........................
- rs turbo s2 injection problem
- consequences of water pump failure. FRS?
- Mondeo MK4 Fault Codes/Electrical Problems
- Saph Ecu
- mk6 wishbone problem update
- problen with gearbox
- full engine replacement
- series 2 brake pipes no abs
- t4 turbo- exhaust housings
- HELP
- Efi speed sensor ?
- Seat Runners/ Subframes
- boost question
- dipsticks
- throttle bodied rs 1800
- koni rear shockers
- ford mondeo 02 plate dual mass flywheel
- escort van pats module location
- exhaust- where to buy?
- Zetec Throttle Body with idle screw info needed.
- Bailey oil breather fitting??? rwd saph.
- electrics series 2 mfi
- saph fuse box
- Efi and mfi
- ISCV connector plug
- 1998 Escort van fuel problem
- BC 5 gearboxes, differences between pre and post '86
- slight loss of oil pressure
- Escort Zetec Runnning problems- saga
- Zetec Loom Compatabilities
- MK1 XR2 Carb problem
- Want bolts on to the block beneath the distributor??
- anyone got an oil breather diagram??
- few escort 1.8 gti problems
- CV joint/ clutch
- venom1 1.8.si estate 1998
- rs2000 cutout no spark or fuel
- Car engine loom
- power steering
- Cool Runnings
- fitting a saph beam/arb to a 3dr
- focus rs engine in a escort,which mtx75?
- Ford Fiesta MK6 (Blower Problem)
- A few problems, Help needed!
- Focus tdci AST system failure?
- new round post battery in cossie
- escort zetec 1.6 alternator removal
- Fan loom for cosworth
- Zetec Missing (Fuel Smell Horrendous)
- 95 escort cabriolet stalling
- how many miles you get to a tank of fuel in your cossies?
- Escort van lumpy idle
- Bosch or siemens ?
- unleaded heads or maybe not
- Converting from RS Turbo to CVH carb LOOM question
- rs will not start
- Steering wheel boss?
- Fiesta rs wont start
- springs
- erst vernier pulley idiot proof ?
- Boost dropped, vacuum pipe going nowhere!
- NO Handbrake
- mk4 fiesta brakes swap
- -31 or -34 actuator
- how to get a wider stance
- escort auto box upgrade
- Fault on 57plate fiesta
- Indoor pool
- Aftermarket Engine Management, Whats Best?
- v reg escort van help
- rewiring fuel pump, s2 rst
- MK6 Escort 1.6 16v Zetec Running Problems
- Focus tdci inlet manifold.
- 1979 Cortina caliper bolt torque?
- focus rs mk1 diff into st170
- -31 actuator
- ABS and Traction Control Light
- PATS transponder receiver wires/pinouts
- fuel pipe brackets
- Powder Coating on to Vactan?
- RS will not fire when hot
- Exhaust Fabrication
- 106 GTi oil leak
- 2.0 zetec conversion on auto escort
- Escort Rs Turbo Wiring loom???
- CVH Pistons question
- Rst fuel issue.
- gizzmo IBC MS
- V6 Fiesta
- misfire through carb
- Cosworth ISCV issues................
- Whos got a red face??
- Confusion!!
- Hard to get into gear
- Cosworth diff oil
- Mk3 Fiesta Battery Light On
- ST170 Fuel pressure sensor problems
- rover 380cc turbo injectors
- Cosworth Turbo Banjos
- fuel pressure regulator
- mk6 escort est springs???
- 2002 Ford fiesta zetec tdci clutch problem
- idle control valve 1.8 gti
- Fuel Pump. Mondeo MK3 2001 1.8 petrol
- custom rs turbo ecu chip ?
- head settings for a group a head gasket sierra cosworth 2wd
- cylinder head
- escort van rear brakes
- Cosworth crankshaft sizes
- escort van airbag light
- Are rs turbo metering units interchangeable
- Fiesta engine help!!!
- fiesta si clutch ratchet... help :(
- how wide
- what size seimens injectors do i need...
- mondeo mk 2 wishbone's
- has anyone bought one of these new cossie idle control valves?
- cosworth... bore wash
- mt75 gearbox
- mondeo door glass removal
- rs500 style intercooler
- XR3I Wiring diagram
- problem with vauxhall gearbox can you help
- gearbox oil leak t5
- wont start!
- please watch and give me an opinion ?
- fiesta st earth wire??
- fiesta 1.4 tdci 2006
- RS1800 airbox?
- Looking for advice on buget Zetec ecu
- Remote key advice
- xr3i oil pump
- Alternator Wires (Zetec)
- 2001 mondeo problems
- rs turbo emissions fail
- idle speed control valve problems
- frst CR
- Torque setting for 4x4 Cossie Engine Mounts
- Mondeo Zetec S-TDCI 6 Speed 130 bhp gear box?
- tddi not starting
- Rear wheelhub MK5 Escort XR3i
- Je pistons....
- Mondeo ST TDCi Tensioner problems...
- Idling & Revving issue, ICV location help - '99 ESCORT
- fiesta mk4 1.3 rev counter
- lowering
- Which Gearbox?? td conversion
- 15 inch
- Cosworth ABS help!
- 2.0 cams in a xr2i
- engine dropped and few other qs...
- rev counter
- serious help needed, rs turbo flooding
- escort gti mk7 susp kit
- Where to get S2 fuel pump bracket
- ford mondeo central locking problem
- Escort Van running problem
- EGR valve vac line problem
- wire rev counter to megajolt
- Sierra cosworth/borg warner part
- Zetec cams fitted wrong way round
- Cosworth mot emmisions ?
- Half Moon Seals
- Where's my solenoid?!??
- uncontrollable revving problem.
- poor fuel economy on Zetec?
- wilwood calipers on a series 1 escort
- compression readings ?
- escort van not starting on key and rough running
- Focus springs
- Twin 40s On A Zetec
- melted plug help!!!!!!!!!!!!!!
- MK3 Escort steering column repair kit?
- MT75 gerabox pats
- escort rs 2000
- Steering Vibrates loudly when braking
- No dipped beam on escort rs turbo?!?!
- Help with rust
- FWD to RWD
- F.A.O Mike Tank AKA Woody
- rs 2000
- help help charging problem
- l8 ecu connections
- focus recalibration PCM cost?
- should i get a upgraded fuel regulator???
- your expertise please...
- saph ABS
- Ashley Exhausts
- Escort RS Turbo S2 interior blower problem
- 24v on carbs ??????????
- Air to Air ????
- torque settings????
- upgradein turbo
- 1.3 > 1.6 cvh
- XR3i Efi to carb
- focus wont start? and how do i test the spark
- fiesta st engine removal
- ford focus central locking
- Can anyone help please ???
- deisel problem
- Zetec G/Box mk4 Escort
- PF Guru's...help!! Misfire!!
- Running probs with nice XR3i
- head gasket problem or worse
- Wiring Diagram Escort Rs2000 mk6
- focus help
- Need help please
- MOT help
- Cosy engine breather system
- HELP! Amp troubles!
- Mondeo Zetec-S TDCI oil leak and fourth gear problem.
- Best place for a tunning setup in the midlands?
- mk4 escort loom what does this do ?
- ford key cutting
- Basemap needed
- Mk3 Escort Zetec on Throttle Bodies
- S2 Rear Disk Conversion Problem
- ABS and TC lights stuck on
- Focus Zetec allowable head skim?
- sunroof drains and leaks
- Escort cosworth rear brakes
- lowering my focus problem
- ANOTHER gauge thread! lol
- XR2i MissFire.. PLEASE HELP!
- 2005 st170 power problems
- 4x4 running problems
- Boost on fiesta rst
- Escort Rs turbo tune up needed
- Fiesta ST Ecu pinout
- Falcon Predator EVO4
