ABS and Traction Control Light
Old Feb 18, 2010 | 09:03 AM
leegoodlad's Avatar
leegoodlad
Default ABS and Traction Control Light
HI
My traction control and abs lights are contantly stuck on and my car is due an mot so i need to pick all you guys brains for help. The abs and traction control operate fine, the fuse is not blown and disconnecting the battery over night to reset the ecu did not work.
Any ideas anyone??
Old Feb 18, 2010 | 09:48 AM
oldford's Avatar
oldford
With a lot of makes and models a lit abs-light means the abs and/or traction-control is disabled.
Have the codes read by a dealer or independent with the right equipment. That will narrow down the search.
Make, model and model year of you car could also help.
Kam B
Sep 24, 2015 10:40 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
The Enigma
Sep 12, 2015 10:12 PM
markk
Sep 9, 2015 08:11 AM
fuzzy
Sep 4, 2015 10:11 PM
