fiesta mk4 1.3 rev counter
Hi
I have a 1.3 fiesta mk4 with no rev counter. If I fit the clocks from a mk4 fiesta that has a zetec engine with a rev counter, will my 1.3 be compatible. I know some cars are wired for a rev counter but it wasn't included within the low spec models, so was wondering if I get some clocks from a zetec fiesta/puma, will they plug straight up??
dave
dave
No, theres no sender, which is why the digi dash doesn't show revs in the revs bit.
You just need to find a 'pulse' and use an electronic rev-counter, tis the easiest option.
Or, just mtfu and use ear/speed. 1st is just under 30, 2nd under 50, 3rd under 70, 4th about 100ish, it runs out of puff, and 5th is a m-way cruising gear, if its a 1.3, which, if it is, it won't be a zetec. It'll either be a 1.3 endura, or a 1.25 zetec...
its a 1.3 endura, but am in the rigours of looking at future engine conversions. Someone had mentioned that you could try pulling the clocks out to see if there was a dormant cable for a rev counter. If so, stick one in from a better model, but if there's no rev counter cable I'll get an after market rev counter and sort something out that way
Theres no such thing as a "Sender" for the rev counter, newer cars use ECU for signal sure your one would, more than likely the loom is already there for it just need the dials from a higher spec model to fit.
Martin
Martin
TPM961
15-01-2018 11:50 AM
Mark_
40
02-10-2015 05:40 PM
