Hard to get into gear
Old Feb 16, 2010 | 06:56 PM
rsdan2evn's Avatar
rsdan2evn
Default Hard to get into gear
I have replaced the box with no probs and it has been fine for 3 weeks. But all of a sudden its started to get hard to put into gear. When the engine is turned of its fine, and the also fine when it first turns on. But after it warms up is when it starts to get hard.
Do you think that it might need more fluid, because i checked it and it wasnt leaking out, so i assume that means it is not full, if its not this what else should i check?
Old Feb 17, 2010 | 03:15 PM
rsdan2evn's Avatar
rsdan2evn
anyone
Old Feb 19, 2010 | 12:37 PM
martysmartie's Avatar
martysmartie
What car is it, is it difficult to engage any gear at any given road speed? Normally I fill the box till the filler plug level. So yes it would be good idea to add little oil.
Martin
Old Feb 19, 2010 | 01:13 PM
essexRSTSouthend's Avatar
essexRSTSouthend
get a paper clip and bend it out.rest it on the thread where the plug was and you will get a reading.make sure the clip is half way down and not straight.let us know what reading you get.as said above,fill it up,get a light and you should see the oil near the plug level.getting the oil in is the fun part.
sridgett
Oct 1, 2015 07:30 PM
The Youth.
Sep 30, 2015 09:59 PM
SMILER258
Sep 28, 2015 09:04 AM
