MK6 Escort 1.6 16v Zetec Running Problems
Old Feb 19, 2010 | 12:30 PM
grandman's Avatar
grandman
Default MK6 Escort 1.6 16v Zetec Running Problems
Hi,
I have a UK MK6 1.6 16V Escort Saloon Reg in 1996. From cold the car starts well and runs, until operating temperature is reached (or maybe engine has been running long enough for this to happen).
The initial indication is erratic idle, the revs can drop to zero and still recover, (as if hunting for fuel), (Not fuel, we checked this other day when fault occurred) this will be accompanied by the car start to kangaroo if you keep driving, and, eventually the engine will just cut out, the car will restart immediately.
I have replaced every sensor, (that I know of) and (coil pack, plugs, HT leads, C.A.T) Have even changed engine and gearbox. (old engine done 105k new only 49k). had on diagnostic computer and nothing (was told this ECU does not retain error codes).
Simple question any ideas? Were we go next...... have read about PCV valve? would this cause this and were is it? Also something about a cannister system, again I have a cannister located front left of engine bay (driver side) not sure what it does, or if could cause theses problems?
Any help greatly appreciated.
APPENDIX have a little MK3 Fiesta can I get help on that here?
Kind Regards G)
regards
Old Apr 28, 2010 | 04:25 PM
craigostreet's Avatar
craigostreet
did you check lambada sesor off manifold? Is there a kn fitted? Also when you changed the engine, did you change the ecu also>?
Last edited by craigostreet; Apr 28, 2010 at 04:26 PM. Reason: forgot to add summet
JoeyBoyden
Jan 4, 2024 02:36 PM
turbobill
Aug 9, 2015 05:21 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
