mondeo door glass removal
Hi. I need to replace a broken drivers door window....local scrapyard has one but haynes manual says you have to lower glass before removing....
so is it possible to remove glass without lowering it, cos obviously the electrics won't be working on a scrap car. thanks for any help. (mk1 glx mondeo).
You will struggle, there are two central bolts that need to be removed to take the glass out, You might be able to force the scissor lifts down manually but it will be a struggle.
depends what year mondeo..easiest way is to cut the cable and force the glass down..mk1 mondeos have two 8mm bolts to attach to the mech and later ones have 2 clamps using 10mm bolts.never seen a mondy with scissor style mech mind
thanks.....i got it out!
I had to cut through the upright ally channel & then through the cable (with a dremel). Took about 10 mins & 2 cutting discs. Couldn't have done it at a scrapyard though cos no elec supply & i don't have cordless dremel! Many thanks to those who replied.
mrice0107
21-08-2015 07:55 PM
borboyous
14-08-2015 06:51 PM
