Fuel Pump. Mondeo MK3 2001 1.8 petrol
Hi All
I've changed fuel pump( the one inside tank) two weeks ago and is down again. What can cause it? Wasn't me to change it last time so i cannot tell if fuel filter was ok. You can still hear the pump working but just not passing the petrol through. Car is 2001 1.8 in petrol
Duratec. Now the car dont want to start at all but before revs in idle has been up and down all the times. Lack of power when warm and need to switch the engine every couple miles
It could possibly be the water temp. sensor on the ecu side not the guage one mate. If it's faulty then it is telling the ecu to over fuel hence the problems with starting and when the engine is warm. A diagnosic check would show it up and it's a cheap and simple fix. I've had this happen on a few customers cars so hope it is of help to you.
Sheepdisease
30-08-2015 09:11 PM
