PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 [82] 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114
  1. Twin dellorto 45's or single dellorto 48
  2. Koni Damper Settings
  3. can anyone post up instrument cluster wiring diagram?
  4. mfi metering head/ injector query
  5. Sapphire heater/water noise.
  6. knocking please help
  7. series one. no spark
  8. Battery or Alternator
  9. Fiesta rs turbo engine in to mk5 zetec s
  10. 1.8 16v pats/ecu
  11. Ignition barrel problems
  12. S2 TPS... how important is this??
  13. (((wires from a s1 fuel pump relay)))
  14. hi guys,what turbo charger is this?
  15. banjo fittings on t34?
  16. 2wd cos abs vidrating pedal
  17. 1.6 zetec loom help urgently needed. please
  18. Water leak
  19. amal valve
  20. what are these pistons in my 2.1 ZVH please help
  21. Help - seatbelt pre-tensioners + airbag light
  22. S-max wheels
  23. 7/16 unf
  24. Fiesta 1.4 TDCi Hesitation - MAF??
  25. Immobiliser light on clock fault??
  26. SILLS
  27. s2 gearbox
  28. Zetec cams
  29. revs sticking
  30. escort cab gearbox limiter?
  31. Rear Bumper MK6 Escort
  32. fitting a head and kent cam on a frst
  33. FRST problems
  34. instrument cluster upgrade to tacho?
  35. cossie water pump
  36. cossie fuel pump
  37. HCS - ZETEC conversion advice...
  38. HCS - ZETEC conversion - mk3 fiesta
  39. head work
  40. Cosworth engine blowing out gaskets
  41. cosworth water pump
  42. What are the best injectors to use on a 2.0 Zetec Turbo?
  43. 1.6 Zetec to 2.0 Zetec Conversion??
  44. pinking / detonation - help!
  45. HELP! Puma Variable Cam Timing????
  46. Escort 1.6 zetec bypass air con pump??
  47. help with vecta immobiliser on escort cosworth
  48. escort cosworth 1993 amal valve
  49. springs and shockers MK2 Mondeo V6
  50. rover v8 not starting
  51. xr2i rear lights?
  52. stolen rst???
  53. Upgrading Springs & Bushes...
  54. calling all suspension guru`s
  55. mfi rst fuelling ??
  56. anyone with pictures of 4x4sump and 7.5 r&d front diff?
  57. Renault Clio Question
  58. cossie discs and calipers on a s2
  59. cossie wheels
  60. s1 wheel help
  61. Knocking
  62. what goes where on amal valve s2
  63. escort cabby roof not working
  64. the most unspecific problem ever?
  65. no boost no dump valve
  66. Non starting XR3i
  67. AFR on N/A car ??
  68. volvo t5r,what gearbox for a rwd mk1/2 escort
  69. Adjusting the boost?
  70. HELP.....Fiesta 1.6 Si
  71. cosworth head cam lineboring
  72. is itsafe tobore a 2.0 zetec to 3.406"
  73. escort td
  74. Just bought this for my fezzy turbs
  75. Would these Beige Injectors be suitable for Fiesta RST
  76. Actuator bracket....??
  77. Brake upgrade ???
  78. cosworth fuel pump on frst idle problems helllllp
  79. s2 rear arb
  80. zetec oil galleries question
  81. no drive
  82. drop off 5.1 gear
  83. cossie noise
  84. puma overrevin
  85. Lowering springs
  86. What Clutch????....Recomendations please!
  87. S2 RST Rev counter
  88. master cylinder for escort
  89. timing for modified rs turbo
  90. binding brakes
  91. Carb calculations
  92. 2.0L Pinto & Holley Carb???
  93. 2wd Cossie ACTING STRANGE
  94. Funny accelerating Escort Cosworth
  95. HELP - Electric car
  96. erst low boost
  97. Help is it fuel or something else?
  98. Stainless nuts and bolts whats the web address
  99. Rich/lean mixture cosworth sensors
  100. Weight Reduction
  101. wireing help
  102. engine conversion
  103. Lamda sensor and Cam Shaft Senor
  104. What oil?
  105. Morette spares
  106. Wastegate Penny
  107. XR3I cabby help
  108. sierra cossie (3dr) owners with group A air filters *HELP*
  109. Engine numbers on Sierra Cosworths
  110. Ford Fiesta Zetec Headlamp Problem
  111. 4x4
  112. 4wd head on 2wd block?
  113. Cos 2wd head cam bearings?????
  114. xr3i fuel pump
  115. Help Whinning rs1800 gear box/engine
  116. cossie plugs in a RST, benefits please?
  117. HELP!! overfueling 3door cos
  118. Fiesta RS Turbo engine problems
  119. Reconditioning T2 Turbo
  120. What cambelt for 2.1 ZVH using 1.3 CVH tensioner
  121. EGR bits n bobs on a Zetec - how to remove ?????????????????
  122. ztec in a mk4 escort help plz
  123. Mk1 Xr2
  124. Convert 4 to 2 wheel drive sierra cossi.
  125. REV COUNTER (LAZY)
  126. zetec problem
  127. wiring ?
  128. Limits of cossie TB
  129. Saph cosworth very low oil pressure. Whats wrong???
  130. price on group a/wrc front driveshaft
  131. judder / backfire
  132. Cossie Running Gear
  133. Help With Mk 4 Escort Van!
  134. Help! - Fiesta 1.25 Zetec Heating Problems!
  135. Turning up boost
  136. Fiesta Rst Not Starting
  137. Greddy Profec B Spec 2 Boost Controller Settings ??????
  138. bonnet struts for mk4 scort
  139. Type 9 Gearbox
  140. wire ringing
  141. mk 4 cabriloet install
  142. costina bottom hose
  143. ESCORT
  144. 3dr power steering pipe
  145. Motorbike TB's
  146. Oil Leak
  147. need some serious help
  148. cossie oil leak
  149. Running problem on my ZT fiesta turbo *URGENT*
  150. Feul pump
  151. Will it still run ?
  152. got a car that needs scraping
  153. cam questions
  154. injector flow?
  155. injector problem
  156. XR2i Tuning
  157. mk6 zetec engine into mk5b
  158. idling issue
  159. HELP :( :( (PICS)
  160. sierra hatch steering column lower bush
  161. FL message on SPA dual gauge
  162. ignition advance etc....
  163. No boost reading
  164. NITROUS KIT ?
  165. Replace rear bearings on Ford Fiesta 1.3 LX
  166. FAO Engine Builders - De-stroking engines?
  167. BLEED VALVES!!!
  168. What Compression Are Standard Cossie Pistons?
  169. AVC-R BOOST CONTROLLER
  170. Web adress of Pace Product
  171. turbo retaining nuts
  172. Borg Warner T56 mechanical speedo
  173. cosworth cam belt
  174. Fluctuating Cosworth Engine
  175. Genuine XR3 carb turbo
  176. Fogs not working
  177. ZVH N/A Ideas? :)
  178. cos rad gone bananas
  179. oil pressure
  180. is it my cam belt
  181. red stripes
  182. cossie suspension
  183. Discussion on Cossie understeer and Rear Beams (title edited
  184. 5w40 fully synthetic oil
  185. Suspension on a KA?
  186. mk 5 escort cab judders
  187. Inlet air temp sensor
  188. xr4x4
  189. indecators stay ing on
  190. what tool do i need for
  191. Ticking noise on Ka
  192. block piece for the oil feed...
  193. escort mk2
  194. help with 6x9s
  195. what does a cossie LSD look like
  196. Doors on a Puma
  197. t34?
  198. How do you check the timing with verniers??
  199. is an f reg 1.1 likely to be 5 speed?plus mpg ??
  200. Mk4 Steering wheel boss on a mk5 escort cosworth?
  201. Fiesta turbo distortion problem
  202. XR4x4 2.8 Help pleeeeeeease!! :o)
  203. Brake upgrade for xr3i
  204. * RS7 Wheel problem * (Also in Escort turbo room)
  205. 2ltr mondeo head on a escort 1.8si?????
  206. xr2i 16v clutch problem
  207. xr2i no rev?????
  208. GT25 turbo on an rs turbo cvh???
  209. Help! : Attention all CVH Owners
  210. Engine wiring
  211. mk6 2.0 zetec conversion
  212. mk5 cortina pinto conversion to cossie 205???
  213. YB Engine to 2wd MT75 Gearbox?
  214. xr2i immobiliser problem need help!
  215. Which is the best LSD for a 7.5" Diff ?
  216. Puma Remote Key Probs
  217. Gear linkage S2
  218. pinking (pre-ignition)
  219. boost/vacuum problem
  220. Bad oil leak while driving
  221. quick relay question
  222. Anyone running omex 600 engine management?
  223. front wheel bearing
  224. Oil Sump Gasket
  225. Ka wiring diagram?
  226. Mondeo exhaust
  227. Problem with XR3i,Fuel pump cuts out when warm,please help
  228. focus rear wheel beraing help again
  229. Weber alpha remap required I think, help!!
  230. Modified 2WD Sump to accept oil return from Bailey Breather
  231. strenghtening the 4x4 sump?
  232. oerbosting and pinking
  233. 2.0L Mondeo Engine
  234. focus rs engine managmentlight problem.
  235. pistons and rods (best?)
  236. Hard to start
  237. Mk5 pedal conversion for S2
  238. Mondeo Alarm Problem
  239. Mk4 escort zetec conversion
  240. deflex bushs (help)
  241. mondeo smartcharge!
  242. zvh boost
  243. trim help
  244. Slight oil leak from turbo oil feed????
  245. Rs2000 With throttle boddies?
  246. wheel arch rolling
  247. Pre '86 CVH cross-hatch head castings
  248. ENGINE SWAP!
  249. Escort van upgrade
  250. saph cossy speakers???
