Immobiliser light on clock fault??
Hi guys,
i have a fault with the immobiliser light by the clock which is flashing all the time with ignition on/engine running. but it doesnt flash with ignition off
starts and runs fine, any ideas?
car is: 1997 escort 1.8 diesel van
Thanks Matt.
Thanks Matt.
Might be the module fucked my other half had the same problem that started like your's. The light was on when the car was on then went off when you turned the car off it was like this for ages then one day it would'nt start at all
i disconnected it from the module and is started stright up so like i say might be your module on it's way out
If you do disconnect it your alarm wont work at all so might be worth getting another module and trying that if you need the alarm to work if you aint got an aftermarket alarm fitted
nipper.1
Ford KUGA
12
May 30, 2022 07:39 PM
TPM961
Jan 15, 2018 10:50 AM
155lee
Oct 24, 2015 11:11 AM
The Enigma
Sep 12, 2015 10:12 PM
