Non starting XR3i
Old Nov 18, 2006 | 04:35 PM
BBSparky's Avatar
BBSparky
Default Non starting XR3i
Hey everyone.!
Im struggling with the ongoing saga of my non starting 88 mk4 XR3i mfi cabriolet and have a couple of questions. Having called in a local 'mechanic' but im still no nearer a working car so have collared my workmate and been trying to solve it ourselves. Quick bit of history:
Car was running, was just letting it warm up before going for a drive and it just cut out. Since then it has not started and there is no spark at the plugs. Have confirmed that there is fuel getting in. It has had a reconditioned distributor fitted and a replacement coil which i was assured was fine.
Today we have been having an investigation with the help of a multimeter and this is what we have found.
We checked the wires on the plug on the ignition amplifier and got the following results
Black - 12v with ignition on all fine
Brown - Earth and all fine
Green wire has continuity so not broken.
Did find that the mechaninc had taken them all out of the plug(!) so need to confirm the order
Reading from coil
+ve wire to coil reading 12v all ok
-ve wire to coil earth all ok.
but with ignition on the output from the coil was 8v
Ok here are my questions ( and thanks for sticking with me! )
- What should the order be for the wires in the distributor amp plug?
- Is it right that the coil is only putting out 8v?
- Is there a way to test the ignition amplifier?
- Is there anything else im missing?
Thanks for your time
Old Nov 18, 2006 | 05:11 PM
Wardy257's Avatar
Wardy257
You need to volt drop on cranking or with the engine running. Are you getting coil switching?
Old Nov 18, 2006 | 09:39 PM
BBSparky's Avatar
BBSparky
Hi, thanks for the reply. Hate to sound dumb but what do you mean by coil switching?
Old Nov 23, 2006 | 04:55 PM
BBSparky's Avatar
BBSparky
Hey guys,
Just realised my post may not have been so clear. The reconditioned dizzy and coil were added after the car died. If anyone has any ideas what i can check it would be most appreciated and if anyone could have a look on theirs and tell me what order the wires go into the ignition amp so i can cross that off the list i would be eternally thankful
Old Nov 24, 2006 | 08:39 PM
SafeChav's Avatar
SafeChav
What dizzy are you running? Blue or black cap?
Have you done a primary and secondary winding resistance test on the coil?
Ignition amplifiers can be tested, theres expensive ass pieces of equipment to do it from what i know
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
stevierob
Sep 7, 2015 07:09 PM
