PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114
  1. Ford Escort 1.6 L Zetec
  2. Brake problem on my 2wd cosworth
  3. Will a 200bhp rs turbo be reliable??
  4. ZVH oil return.
  5. 4wd fuel pump relay wiring fault!!!!
  6. amal valve
  7. IS it a Fiesta RST fuel pump Or an Escort Cosworth?
  8. sapph stage 3 problem boost/fuel?
  9. 2WD diff
  10. 2 questions
  11. ecu
  12. Escort Mk4 engine swap XR3i to Diesel
  13. zvh starter motor
  14. Mk4 Escort not turning over
  15. GTIR inlet manifold on ZT, how hard to fit?
  16. Escos wiring faults.+ boost/ misfire prob
  17. mk4 xr3i efi misfire/hesitation low revs on high load
  18. Transferbox - what oil or fluid?
  19. Do late escort cossie pulleys fit on 2wd cossie
  20. No boost and wont rev past 3K rpm? Limp Mode?
  21. 1.3 cvh cam cover fit a 1.6 rst engine??
  22. Mondeo TDCI - Flashing Glow light?
  23. Advice on spring rates
  24. speedo not working
  25. Crankshaft & Pistons?
  26. morette headlights - bumper indicators
  27. Driveshafts on ZVH engine.
  28. xr3i mfi 89 quick shift be a good buy?
  29. Stainless Steel Exhaust Assembly Advice
  30. please help with my rs turbo
  31. Focus rs pistons in silver top.
  32. cossie ford pilot
  33. replacement engine, will my chipped ECU be ok to run it??
  34. Vacuum leak between throttle body and servo one way valve
  35. old skool wheels not on old skool
  36. Fiesta TDCi EML Problems
  37. mndeo mk2 td parts/breaking to use for escort mk6 van
  38. Mk5 Fiesta Brake issue
  39. Front strut removal.
  40. Cosworth compression strut questions....
  41. ZVH sump capacity.
  42. Focus ST170 and fitting Brembo's
  43. cossie exhaust
  44. ofac or ofab?
  45. 36-1 trigger wheel on a yb .
  46. p100
  47. No pipe on actuator.
  48. Help me, think I just bought a dog!!
  49. Power Hood Not Working
  50. escort s1 rs turbo roll bar
  51. adjustable tca's-ball joint
  52. Rust repair advice, wanted
  53. Ignition Problems
  54. mk5 erst s2 conversion overfueling
  55. Timing on mk5 Escort van 1.8d
  56. High/Low compression pistons in FRST
  57. Escort RS Turbo Jerky.....
  58. Overheating problem- Fiat
  59. erst s2 rev counter not right
  60. Heater on 1997 escort van
  61. Afr gauge fitting
  62. no heater in mk4 astra van please help!!!!!!!!!!!!!!!!!
  63. xr3i alternator
  64. mk5 erst s2 conversion overfueling
  65. Escort Mk3 Rear Chassis/Boot floor
  66. rs2000 no spark
  67. escort van 1.8d start
  68. ford transit gear selector
  69. Fiesta mk6 bumper and brakes help!
  70. gearbox
  71. Mk2 Escort Rack
  72. alternator's..
  73. st170 gearbox conversion
  74. Is there a connector to lubricate the prop shaft somehow?
  75. rs turbo no spark
  76. **Wiring help/ direction on the s1 escort**
  77. White smoke help please!
  78. missfire as comes on boost
  79. what is a safe boost on 2.0 zvh
  80. Fiesta Engine loom re-wiring.
  81. Mk3 Fiesta driveshafts, all the same?
  82. Whats easiest...engine and box fitted together or engine in and then box.
  83. Escort Rs2000 MTX75 into a fiesta rs turbo, what work needs doing?
  84. Central locking being fussy!
  85. Zetec on ITB's
  86. Ford Focus TDDI FUEL PUMP
  87. swaping to efi whats needed
  88. Escort Mk4 Heater Matrix Change
  89. help please! escort zetec
  90. COSWORTH...ARP and normal head bolts!!...
  91. patch leads for 97 escort
  92. Fao cosworth s.e.c.s monitor owners
  93. Which Exhaust Housing on GT35R?
  94. mk4 1.4 zetec fiesta help
  95. Escort Cosworth Oil temp in Head???
  96. Strange when braking maby ABS?
  97. s2 rst not boosting ?!?! :( help!
  98. Adding an electronic fuel pump
  99. Escort RS Turbo Misfire
  100. reversing lights not working, escort van wiring help needed
  101. do mk 3 fezza turbs 1.6cvh efi have a knock sensor??
  102. mk4 fiesta 1.4 zetec suspension
  103. turning up boost? older 1.8 td
  104. Mk4 Escort Heater Matrix
  105. will spax shocks/springs from my xr2i fit my mk2 mondeo?
  106. Fiesta Van Suspension
  107. bleeding brkes
  108. driven 1000 miles now car dead again
  109. bleedin sump gaskets!!!!!
  110. fezza turbs pinking
  111. renault kangoo help.
  112. Boost explanation
  113. Maximum Power 8 Dark Green(803)Injectors
  114. small turbo phase sensor voltage.
  115. MK1 Orion & MK4 Escort Suspension - Same??
  116. erst cut out and now will not start
  117. Nuts, Bolts and Screws for mk5 Fiesta
  118. zetec s silver top knocking top end?
  119. Pinto 2000 vacuum pipes.
  120. fireing on two cylinders
  121. mk6 dash in a mk5 need some advice :)
  122. wiring diagram needed!
  123. Bodykit
  124. power steering red hot? why.
  125. help please
  126. whats better to use for the zetec turbo conversion
  127. Fiesta 1.8TD - OBD software
  128. Help! Rev counter not working and battery light!
  129. wiring guru's / electrical help require, focus R dash removal
  130. Help can you adjust FSE boost valves
  131. Fiesta 06 Mk6 New Alloys Help ? :D
  132. 2.3 granny block
  133. ZetecS Beam On RS1800?
  134. turbo newbie help
  135. Tensioner 2.5 v6 1997 mondeo
  136. Boa 24v cosworth,no start,no spark (please help)
  137. PLS HELP will a mk1 focus gearbox fit mk2
  138. Map Sensor differences....
  139. cosworth engine help
  140. 6000cd code - help please
  141. hey tech head's :)
  142. Wheel bearings
  143. Fitting 2007 ST Focus Oil & Boost Pressure Gauge to 2006 1.6TDCI focus
  144. xr3i mfi running rich
  145. abs brake pedal bounce
  146. fuel guage not working please help
  147. judder while driving help please :(
  148. 55 plate ford connect van
  149. big brakes
  150. Rolling Road in South?
  151. Escort 3i to rs turbo
  152. removing pvc valve on zetec
  153. urgent help needed bailey oil seperator fitting
  154. 2 litre zetec in my mk3 estate
  155. rs 4spoke steering wheel to mk3 fiesta fitting?
  156. l reg escort van rear bearing removal
  157. rev counter wire color help please
  158. inlet manifolds, what to use?
  159. Exhaust cam seized - What to do?
  160. any one know what this is
  161. door panels cosworth
  162. mondeo clutch
  163. very high revs on turn over
  164. Focus St170 Fault Codes P0135 P0141 P1518
  165. bailey oil seperator help needed please
  166. FRST leaking. Oil or fuel????
  167. Does some one have a chip to sell ????
  168. gt28rs turbo, will it fit on a .....
  169. auto box only drives in 1 and 2 mondeo mk2
  170. Xr4x4 front shafts to cosworth. Fact or Myth??
  171. XR4i Full Beam will not turn off!
  172. Silvertop Zetec Dhoc -Zetec16v
  173. Wanted: Loom Maker
  174. Radio wiring diragram please help
  175. ofac help needed
  176. ECU Loom parts help
  177. 4x4 lowering springs.
  178. Braking Issues
  179. Escort cosowrth clutch .. help/advice please
  180. coolant problems
  181. Studs & bolts for CVH Rsturbo
  182. Cosworth Brake disc's!!!!
  183. steering problem
  184. HELP ASAP what ratio master cylinders/servo for my car??
  185. saph cosworth front drive shafts
  186. Focus ST170 funny noise?!?
  187. Coolant level on 2WD cossie
  188. my new xr3i needing techs advice!
  189. Central locking not working
  190. Tyres for Comps
  191. clutch gone.....
  192. rebuild s2 gearbox?
  193. high idle
  194. causes of serious over fueling?
  195. fez mk6 dash swap
  196. 2wd sapphire floating at speed
  197. HELP!!! Radio Code
  198. Reverse Lights dont work
  199. Hi newbi here idle problem
  200. focus RS pistons an rods!
  201. Cosworth 2wd Brake pipes???
  202. Poor Handling Focus ST
  203. 2wd rear axle removal
  204. rev counter issues
  205. st170 wheels
  206. t5 gearbox problem
  207. S2 ERST gone bang?
  208. turbo question...
  209. Is windscreen different on mk4 escort cabriolet to hardtop?
  210. power steering in general :S
  211. fuel is coming from my throttle body
  212. my metering head filles with fuel
  213. 4x4 cosworth fuel pumpproblem
  214. ford endura di turbo diesel throttle sluggish
  215. CVH oversize main bearings????
  216. 1.8 zetec surging..
  217. more problems
  218. wheel offset
  219. need help ASAP cars locked but running!
  220. Ford Zetec Estate rear tailgate lock
  221. Zetec estate 200 - central locking problem
  222. Problematic S2
  223. Which Is the best oil to use in Lsd S2 gearbox?
  224. MK2 Mondeo front springs
  225. Focus 1.6 Zetec Lumpy HELP please
  226. 51 mondeo cooling fans
  227. Rear Ligh Problems PLEASE HELP
  228. this is killing me ..metering head
  229. fuel pump relay
  230. Cams/Pulley question
  231. doubts to instal 9" ford motorspor rear diff in a sapphire cosworth 4x4
  232. rear axel and rear beam of sapphire cosworth 4x4 compatibili other models ford
  233. Mk.6 Fiesta Alloys help!
  234. cossie steering
  235. 3dr dash warning light module
  236. Mk6 Escort 2litre conversion
  237. brakes
  238. Focus st170 clutch change
  239. 4x4 cosworth turbo swop on 2wd
  240. fiesta 1.4 16v r plate itermitant starting problem
  241. 02 focus diesel faults
  242. hybrid t3 . what power?
  243. zetec turbo has peak power only at 5200 rpm
  244. spark plug gap
  245. mk2 focus towbar electrics ??
  246. cosworth belt trouble
  247. Silvertop/Blacktop alternator question!
  248. Fuel pump wiring
  249. differences between Endura and Kent heads?
  250. zetec loom help
