Pinto 2000 vacuum pipes.
Old Nov 3, 2009 | 10:56 PM
paintman's Avatar
paintman
Default Pinto 2000 vacuum pipes.
I got a pinto in my Kit Car running with a weber DGAV carb. Just bought it .... runs well when warm but pops and bangs when cold!
The vacuum pipes don't appear correctly fitted as there is only one pipe coming out of the water heater vac. switch (attached to the water pipe), leaving the second outlet sucking air! If I seal it off the engine cuts out!
Can anyone tell me where all the vac. pipes should go inc. the carb and distributor please.....or some photos. Its driving me maddddddddd!!!
Cheers...Paintman
Mark RS
Oct 12, 2015 06:01 AM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
20/20 vision
Sep 29, 2015 11:27 AM
